by Chug » Tue Feb 16, 2021 9:36 pm
Use an impact driver, or get underneath and give them a good wire brushing then spray with penetrating oil, then back uptop and put an old screwdriver in the head and whack it with a hammer to shock it and then with a good fitting screwdriver put mole grips on it for better leverage and then put maximum downward pressure (get yer weight behind it) on as you turn the screwdriver, if this fails get an impact driver.
