Roof light conversion.
Postby Transit460Camper » Wed Mar 17, 2021 9:26 pm
We have a transit 460 minibus.
It has a fixed roof light which also doubles as an emergency exit.
As part of the conversion, we want to make this openable.
Has anyone done this to any model?
Or would it maybe be best/easier to just remove the rooflight completely and install an openable one, or even leave the roof light as is and install a separate roof vent.
Any guidance or recommendations would be appreciated!
Transit460Camper
Re: Roof light conversion.
Postby dumper » Wed Mar 17, 2021 10:44 pm
I looked at this when doing mine but couldn’t come up with anything in the time available so in the end I insulated it and boarded it over but would have been a good idea.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Transit460Camper » Thu Mar 18, 2021 8:59 am
dumper wrote:I looked at this when doing mine but couldn’t come up with anything in the time available so in the end I insulated it and boarded it over but would have been a good idea.
Thanks for the reply. If we cannot make it openable we will probably curtain it in some way. What did you do for ventilation?
Transit460Camper
Postby dumper » Thu Mar 18, 2021 10:43 am
Open a window or door if it’s hot at night I use a usb drive powered fan as I use mine more in winter this has not being a big problem.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby thebarber » Fri Mar 19, 2021 6:14 am
What size is it, can you not replace with a large heki rooflight?
thebarber
Postby thebarber » Fri Mar 19, 2021 6:17 am
Inner opening 780x530 but christ, look at the price......
https://www.ebay.co.uk/itm/160674855555
thebarber
Postby dumper » Fri Mar 19, 2021 9:48 am
But it would be a good conversion maybe worth the price if you intend to keep van long term.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Transit460Camper » Fri Mar 19, 2021 10:02 am
Thanks for the input folks!
I was hoping to use the exiting rooflight & make it openable, but seeing your comments, I think removing it and installing a new one is the way forward.
Will do some more research and let you know which one I end up with!
Transit460Camper
