Hi all,
I've scanned a million posts on here and elsewhere trying to find a definitive answer to my dilemma, with no success.
So I'm hoping someone here can explain/confirm my thinking
I have a 2010 mk7 LWB that has two factory batteries under drivers seat. I know front is aux and rear is starter
I have installed a new agm leisure battery in rear for "house".
I have 500w solar connected to this through a 40a mppt controller. It's not a dual battery controller, only single.
I have also just received a dual sensing vsr and about to fit, but i be started having concerns about the validity of adding this.
I plan to connect from van front aux battery to vsr, then vsr to the new agm. I also plan to install a breaker near vsr so i can disable vsr if i want
My theory is that when running, vsr still detect increased voltage from van alternator, making a connection to rear agm battery and thus charge that battery.
In reverse, as i read online, with engine off but solar on to the agm battery, again the vsr should engage and the solar charge the van aux battery too. I can use the breaker though if required to focus all solar charge on agm battery.
This is my ideal as it's means van aux benefits from solar when van laid up when not in use.
But my concern now, is that i can't seem to get a definitive answer to is what really happens when engine runs given that solar is also pushing a charge? Engine and solar would both be pushing a charge as such, so what happens? Is that ok?
My theory is that the mppt controller will sense power going into agm leisure battery via engine running and reduce/stop solar charge? Does that seem correct?
Just want to be sure it won't blow up or overcharge?
