Mk)8 minibus conversion.
Postby JamesHow » Tue May 11, 2021 7:19 am
Hi just brought a mk8 15 seater minibus for converting.
Not a full conversion but a day van conversion with the plastics remaining.
Do I need to insulate behind the plastics?
Should I paint the underside as transits are prone to rust?
Many more questions to follow.
This is my 2nd conversion after a movano last summer which died at Christmas.
Cheers James
JamesHow
Re: Mk)8 minibus conversion.
Postby JamesHow » Fri May 14, 2021 6:45 pm
Van is great drives nice - car like really, plenty of power to get over the Yorkshire dales.
Stealing wheel is small! A bit sensitive compared to the master and sprinters I have driven.
Filled up at the garage and read the weight plate 4100kg! Help!! That's not what I thought it was!
Going to have to get it downplayed svtech charge £144.
Doh needs must!
Cheers James
JamesHow
Postby JamesHow » Sun May 16, 2021 10:27 am
Stripped out the seats today anyone want 3 doubles and 4 singles!!
Floor was grubby so scrubbed it, needs another going over!
What's the box at the rear left with vents in see pic????
Then picked up some 4x2 cls and a sheet if plywood.
I envisioned using the cup holders but there is only one in the right area.
So I used that as middle support and the other one simply rests on the ledge. Seems strong enough - a naked van pics shows there is a large steel beam under it.
Ply went on top with 6 large panhead screws securing.
So I can easily revert it to a van for work duties.
I could cut the middle piece in half for extra manvoverability but 3 more screws.
Loo enclosure and kitchen units to follow. The seat lugs will probably suit champing them down.
Pics here
https://www.motorhomefun.co.uk/forum/th ... 947/page-2
Cheers James
JamesHow
Postby dumper » Sun May 16, 2021 2:16 pm
Rear aircon I removed mine had the pipes blocked off as it was taking up room in the storage area and making anything in there damp
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby JamesHow » Sat May 22, 2021 10:06 pm
Hi just an update I've made a kitchen unit 12mm plywood.
Basic but functional .
See link above, I must learn to post pics on here.
Cheers James
JamesHow
