by dumper » Tue May 25, 2021 6:01 am
Mine was only a aircon unit at the back at first i left it in on my conversion it was in a storage area at the back but it started turning everything in it damp even when never used as the coolant ran through it when the front is used so I had it removed and the pipes blocked off by a Aircon engineer. Plus point a bigger storage area my van is a l4 and with the layout taking up a big part of the interior space the front aircon is man enough so having a rear unit is of no use and you can’t use it when parked up at night I didn’t remove the rear heater unit as it is underneath the front passenger seat and having swivels if I removed it I couldn’t use the space anyway.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
