Xzent X-F280
Xzent X-F280
Postby MHbob » Sun Jun 06, 2021 9:55 am
Hi I have a new 2021 transit based Motorhome which has the new Xzent x-f280 fitted. It does not come with the navigation enabled. Can anyone advise me what SD card is required to get navigation please.
MHbob
Re: Xzent X-F280
Postby Noctule » Mon Jun 07, 2021 12:49 am
I think you need this one...
https://www.amazon.co.uk/Xzent-X-MAP27- ... B085996VLN
As far as I an tell the X-F280 is the Transit version of the 270.
2012 Mk7 125t350 camper conversion in progress
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 190 HiCube DRW self-built camper
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Re: Xzent X-F280
Postby Ford Transit F62 » Sun Aug 15, 2021 7:41 pm
Hi I have a new 21 June reg transit auto trail F62 with a x f 280 Zenec sat nav fitted and on collection from motorhome dealers they inserted sat nav memory card he got out a small plastic bag with the Xzent X -280 instructions in so your memory card should be the sealed bag with all the instructions in you should not have to buy one ! contact your dealer and ask where it is as they should have installed it when you collected your motorhome this was part of the PDI Good luck.
PS, Do you have to have the ignition ON to listen to the Xzent radio as it will not power up on accessory position this is common design fault and auto trail won't do nothing about it !
Ford Transit F62
Re: Xzent X-F280
Postby Panyan22 » Tue Sep 21, 2021 9:41 pm
I picked up my new Motorhome Transit based and there is a radio switch in front of the steering wheel in the dashboard well that allows me to use the radio that runs of the leisure battery or I can press the outside of the unit on/off button to listen for 20 mins
Panyan22
Re: Xzent X-F280
Postby PMC52 » Sat Jul 16, 2022 3:15 pm
Hi My name is Paul, We have just bought a 21 plate Motorhome, we have a problem with the Navigation as we are not able to activate the voice part? Can anyone help with this small problem.
PMC52
Re: Xzent X-F280
Postby PMC52 » Sun Jul 17, 2022 10:24 am
Hello We have recently bought a 21 plate Auto trail Motorhome. We are experiencing a problem with the Xzent X F280 Sat Nav. We have not been able to get the voice direction working, the map display of the route is ok but no voice. Can anyone help us as it’s anything! Thanks
PMC52
