Powering a dump load
Postby FCMUK » Thu Jul 01, 2021 8:15 am
I might be over thinking this but here goes
I currently have a solar system of 400w connected to two (in parallel) 110ah marine batteries through a solar controller. The panels are providing way more power than I need to keep the batteries charged and go to various loads.
I want to use that excess to put through a 12v immersion heater but only when there’s excess power being produced. My understanding of the controller is that when its load output hits a certain voltage, it will cut off. That would mean that not only the immersion but the fans, lights etc would also be affected.
I thought if I connected a second controller to my load output dedicated to the dump load, it would then only take the excess power.
So do I need a separate controller to stop all loads being affected?
FCMUK
Re: Powering a dump load
Postby stfvrg » Mon Feb 28, 2022 7:17 am
Hi, you could use a Voltage Monitoring Relay that switches the output to the heaters only when that high voltage is reached. Once the voltage drops, the relay will disconnect.
https://a.aliexpress.com/_vpua2l
stfvrg
