Fitting swing out table
Postby Paulmk7 » Tue Sep 07, 2021 1:05 pm
Hello
Can I check with someone is it okay to drill into the area behind the fuel cap to fit the typical style swing out table or does this go into the tank?
Paulmk7
Re: Fitting swing out table
Postby dumper » Tue Sep 07, 2021 8:50 pm
The filler neck for the diesel tank is on a flexible pipe so if the fuel level is low you should be able to remove it to dril the door post .or if you remove the plastic trim is the holes in the panel to fit threaded inserts mine been a x bus has a grab handle on it so the panel maybe pre drilled .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
