Hi all, I'm considering buying a 2015 transit to convert to a camper but do any owners have any thoughts on the following? https://youtu.be/dZIaZs_pG4A
What's the general thoughts on transit reliability and therefore suitability for conversion?
dumper wrote:I decided as I was retiring that I would start with a low mileage X Minibus from the auction all my other vans had 100 thousand plus this one had 7000 klms on it and 2.5 years old so far it’s had a clutch ( must have been out at some time under warranty or Ford when assembling it left a toque bit on the release cylinder) it needed a turbo at 20.000 mls a throttle pedal it kept losing it so had to turn off and restart to get it back now the add blue has he’d to have a new heater in the tank and still has problems with soot build up and going into limp mode back in Ford now if you get one get one with some miles on it’s back with a bit of luck all the problems will have been sorted by the first owner but when it’s running it’s great to drive.
