Ignition live wire in splitcharge kit
Postby crashlikeanamateur » Thu Jun 02, 2022 8:01 pm
Hello,
I am installing a split charge relay into my 2016 Transit. There is an ‘ignition live’ wire which, I’m. It sure where it’s supposed to go. I have looked at the manual for fuse box and locations. There are several ignition associated fuses. So if anyone can help I’d appreciate it. Failing that, I’ll have to give in and hand it over to an auto electrician.
Thanks for your help.
Ben
crashlikeanamateur
Re: Ignition live wire in splitcharge kit
Postby workbox » Thu Jun 02, 2022 9:44 pm
crashlikeanamateur wrote:Hello,
Ben
for split charger you can use any unoccupied spots in the fuse box that become live when you turn the ignition on.
Did you ever consider b2b charger?
workbox
