B2B - can you get 60 amps alternator output ?
Postby workbox » Thu Jun 02, 2022 9:55 pm
Hi,
Anyone able to get 60a+ outputs from alternator to b2b charger on mk8 transit?
workbox
Re: B2B - can you get 60 amps alternator output ?
Postby bortaf » Thu Jun 02, 2022 10:00 pm
Mispronounced adventures on YT fitted 2 30A BtoBs to a Mk8, might be worth a view ?
Current fleet
Mk7 transit ambulance
Mk1 tourneo connect
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Fusion 1.4TDCi
bortaf
Postby workbox » Thu Jun 02, 2022 10:12 pm
bortaf wrote:Mispronounced adventures on YT fitted 2 30A BtoBs to a Mk8, might be worth a view ?
Thanks! I did exactly the same. I think alternator output is limited to 50a by ford bms.
I have contacted Alex, unfortunately no reply on that yet.
workbox
Postby Blizz » Sat Jun 04, 2022 12:04 pm
It's not limited. You can install two Orions 30A like he did but I always would install a switch so you can choose not to use both at all times.
Cheers,
David
Blizz
Postby workbox » Sun Jun 05, 2022 1:24 am
After moving negative from the starter battery end to the chassis all works perfect now.
Blizz wrote:It's not limited. You can install two Orions 30A like he did but I always would install a switch so you can choose not to use both at all times.
Cheers,
David
Thanks David
workbox
