Transit MK7 Conversion Passenger Seat.
Postby Transit MK7 » Tue Jul 12, 2022 10:04 pm
Hi Guys , I’m currently in the middle of converting a 2011 transit MK7 RHD and I’m looking to remove the double seats and put a single seat in. I’ve seen a few different bits online saying people have put a drivers side seat on the passenger side. Is this possible and if so how?
Transit MK7
Re: Transit MK7 Conversion Passenger Seat.
Postby dumper » Wed Jul 13, 2022 11:02 am
It’s easy unbolt the twin seat and bolt in the single seat it uses one less bolt you will have to swap the seatbelt anchor point to the other side and unfortunately the arm rest will be on the wrong side the only difficult bit is getting the rusted in bolts out of the floor so loads of penetrating oil on them before removal mine came out with a torque bit but from posts on here some are rib bolts if you do a search someone has listed the correct one needed.
Postby Dookit » Thu Jul 28, 2022 5:11 pm
I got a drivers base, just need to cut floor liner and bolts straight in, and I went with seats out a Mondeo (nightmare) just welded in a few plates and drilled new holes, from facebook forum Saab 93 seats more or less bolt straight in with a couple of new holes and looked nice. Put a couple of photos of where I'm at still drivers side to do. If you got a drivers seat just bolts straight in and swap seat belt but I wanted better seats and tbh wish I had went the Saab route as they are super comfy.
Have a look at Ford transit Camper group on facebook for ideas.
Dookit
Postby BelfastVan » Sun Oct 23, 2022 12:25 pm
Transit MK7 wrote:Hi Guys , I’m currently in the middle of converting a 2011 transit MK7 RHD and I’m looking to remove the double seats and put a single seat in. I’ve seen a few different bits online saying people have put a drivers side seat on the passenger side. Is this possible and if so how?
OK II bought another driver seat base (Handy if you want to place your house batteries or a heater) and fitted this in place of the double seat (Predrilled so perfect)
Next I bought a swivel seat to fit this base...matches perfectly on the base
On top of that i bought two very comfy seats (These are KIA Niro )... This will need adjustment of the upper plate ) : 4 extra holes.
Perfect fit no problem with MOT
Aftertough get seats with integrated belt ...
BelfastVan
