2015 Trend 350 Split charge (D+ wire)
Postby John235 » Fri Aug 12, 2022 3:02 pm
Hi folks, my daughter has just bought the above. Makes my Connect look a bit sick!
I am starting to fit this out as her new camper, and want to get the wiring right. I believe there should be a wire somewhere that is only live when the engine is running, as distinct from ignition on!
I think this is referred to as the D+ connection. Anyone know its location and wire colour?
There is also a switch panel in the overhead, two are marked Aux1 and Aux2. I have located a loom in the back with similar markings, but the supply only appears to be about 7volts!
I have just finished removing a PowerAll inverter and all its gubbins, but have yet to remove the second alternator that feeds it! The secondary belt for this was missing, so it did not work!
I am bound to have loads of other queries as I progress, but that should do for now!
John235
Re: 2015 Trend 350 Split charge (D+ wire)
Postby John235 » Wed Aug 24, 2022 10:10 am
[attachment=0]Screenshot 2022-08-24 at 09-37-25 Engine On Signal Via Ford Transit Vehicle Interface Connector - Morey's In Transit.jpg[attachment]As I have not recieved any responses, I have had a look elsewhere, and found this!
John235
Postby richbee » Tue Sep 13, 2022 4:50 pm
I guess it is the same as the one in the Custom, (although I thought it was a 4 pin socket - maybe it is different on the 2.0 - mine is a 17 plate) - I used this for my B2B charger D+ signal - works a treat
richbee
Postby dumper » Wed Sep 14, 2022 6:35 pm
My mk8 was a 4 pin
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
