Tap into Diesel tank of a Transit 2002 MK6.
Postby rechena » Wed Oct 19, 2022 4:55 pm
Hi
Apologies if it has been asked before, and I did tried to check under the van without removing the tank.
Long story short, I"m about to install a diesel heater on my 2002 Mk6 LWD and wanted to know if I can tap into the diesel tank, I noticed that it does not have the same aux port as I see on all YouTubes, but browsing on this forum I've seen someone mentioning a 2002..
Does anyone knows if its possible and if so which kit should I purchase? Thanks for the help.
rechena
Re: Tap into Diesel tank of a Transit 2002 MK6.
Postby dumper » Wed Oct 19, 2022 8:45 pm
You can get a kit from Butler technique drop the tank to fit it on a nipple on the tank sender unit
Postby rechena » Thu Oct 20, 2022 8:08 am
Oh that’s great news. Sorry you wouldn’t have a pic? From the photo I managed to take I couldn’t see any nipple type to attach….
rechena
Postby Blizz » Thu Oct 20, 2022 9:16 am
Not sure on the mk6, you always have the option of drilling and installing the universal pickup that comes with the heater.
Blizz
Postby dumper » Thu Oct 20, 2022 11:22 am
On my mk6 all I did was cut the top of the nipple off and fit a flexible pipe on the sender unit the tank had drop pipe in it so didn’t have to use all the kit I got from Butler technique .On my mk8 I did use the drinking straw and connector it surprises me that it’s the same kit for a mk6 and a mk8 even the fitting instructions and photos are the same for both I personally wouldn’t drill the tank all that will do is give you another place for a leak .
