Duetto heater swap
Duetto heater swap
Postby bov783 » Sun Nov 27, 2022 8:59 pm
Hi all
I have 1996 duetto on a Mk5 long wheel base. The habitation gas heater is P4 Carver.
Although it works it’s hard to start keepings flashing red codes. I want to swap to an Eberspacher but
Unsure about the tank pickup etc. has anyone done this??
Any advice welcome.
Many thanks
Phil
bov783
Re: Duetto heater swap
Postby dumper » Mon Nov 28, 2022 12:25 am
What model transit have you if mk 6/7/8 on the fuel sender unit in the tank on the top of it is a nipple you cut the very tip off it and fit a dip tube and connector to it you have to drop the tank to fit it . this kit you can get from butler technique . For a mk1/2/3 tee into the fuel line I had a Eberspacer in my van but i found it not very controllable so I have replaced it with one of the Chinese ones off eBay you can set it on the thermostat or you can set it on injection pulses per minute from 16 to 55 I use mine on 55 for startup and turning off and 16 most of the time .For the price of £120 for the full kit it’s cheaper to buy then getting spare parts for a Eberspacer
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby MinorMatt » Mon Dec 12, 2022 11:32 am
Mk5 transit has 3 options
Fit a factory fuel sender with a standpipe in it (good luck with finding one!!!)
Fit a standpipe to the tank
Tee in to the diesel line.
When Ford engineering fitted an eber to my highcube, they teed in to the fuel line. When I fitted one in a previous vehicle, I tee'd in to the fuel line.
Postby dumper » Mon Dec 12, 2022 2:41 pm
MinorMatt wrote:Mk5 transit has 3 options
The two x BT a mk 4 & a mk 5 both teed into the main fuel line the mk 6 & mk8 I fitted from the good information on the forum I used the Eberspacer tank kit.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
