Custom calorifier + Webasto Thermotop
Postby Blizz » Thu Mar 16, 2023 12:49 pm
Hello,
I wanted to share my custom hot water system although I haven't invented anything new I think it could be interesting for someone.
I built a custom calorifier. Why custom if there many ones one the market? Basically because I could not fit the market ones where I wanted. My van is a L2H2 (130" MR) FWD wich means it has 10cm (4") more head space inside because floor is lower than RWD/AWD versions.
I started ordering a custom made SS tank with the fittings I needed. A big 1" thread for an electric resistor, two 1/2" more for the inlet/outlet and two small ones for drain/temp sensors.
Ordered with one of the ends unwelded.
Then had a pipe bending company build a coil made of 16mm SS. Welded some tabs to rest against tank walls.
With the idea of taking profit of my solar surplus I installed a 12V 200W resistance. It's slow but quite cheap so I can put a bigger one if I want.
Welded the cap and the coil pipes toghether
Installed some fittings on the coil's ends
As my van is still under warranty I prefer to avoid teeing the engine coolant's system (But it's the v2 idea) so i bought a flashed OEM BMW Webasto Thermotop from salvage yard and tried the system outside, redneck style
After the test which was good, I bought some chimney pipe and end caps to develop the tank outer cover
Cut it to size
Put the water tank inside and let's do a cake. Used insulation PU foam
After curing I cut the excess
Cut some holes on the caps
Finished product
(Continues)
Blizz
Re: Custom calorifier + Webasto Thermotop
Postby Blizz » Thu Mar 16, 2023 12:54 pm
I used a long copper pipe for the tank cold water inlet to be far from the hot water outlet.
Installed a thermostat mixing valve and pressure relief with check valve too
Located the place for the water pipes to go in and out of the van
All my van's water system is done with PERT-AL-PERT pipe and press fittings, made all that was possible to do out
That's the space I designed the calorifier to go, did four holes and installed rivnuts
Phew! All fits and nothing sticks out more than the diesel tank
Before installing the valves and isolating the hoses
If possible, I always like to prepare my wiring outside. This is the Thermotop power supply, starting signal and temp sensor wiring
Installed a Y on the aux fuel port (I already had an Autoterm Planar 2D heater installed on it)
Tried to route all the wiring and pipes the best I could
Crossed to the passenger side over the heat shield parallel to an OEM wiring loom
(Continues)
Blizz
Postby Blizz » Thu Mar 16, 2023 12:58 pm
Designed a support plate and got it laser cut
Bolted the plate to the Thermotop and the set to the van body
Intake and exhaust where temporary, those are the OEM BMW ones cut to fit
Designed a small protection plate to avoid road splash
After some paint and installed
Made a temp support for the expansion tank
The pipes coming/going to the calorifier are under the kitchen's sink
Now I'm using the system completely independent to the engine cooland system. Thermotop takes 10 minutes to rise my 15l hot water tank to shower ready temperature. I plan to connect it to engine's cooling circuit in a future but I'll wait (Van it's still under warranty)
I'm super happy with the system. I installed an intake silencer and still need to installe an exhaust one altought the noise the Thermotop makes is more a "plane" or turbine sound rather than combustion noise.
Hope you like it!
Cheers,
David
Blizz
Postby Altransit » Thu Mar 16, 2023 1:08 pm
Nice work 8)
Postby johnporter11 » Thu Mar 16, 2023 10:40 pm
I see you've used extruded aluminium also....
johnporter11
Postby Blizz » Fri Mar 17, 2023 9:28 am
johnporter11 wrote:I see you've used extruded aluminium also....
Yes, and I love it.
Not cheap but the finish is so good and sturdy...
Cheers,
David
Blizz
Postby johnporter11 » Fri Mar 17, 2023 8:27 pm
Snap!
johnporter11
