Mk8 Transit BEM manual
Postby Arcoshi » Tue Jun 27, 2023 7:32 pm
Hi all, new to Ford vans and helping a friend do camper conversion to a 2019 l4h3. I’m trying to locate the downloadable BEM manual so as I can set up D+ connection and ignition live connection for awning/step and a B2B. Does anyone have the relevant link please?
Arcoshi
Re: Mk8 Transit BEM manual
Postby Blizz » Thu Jul 06, 2023 3:59 pm
Can`t attach it as it's bigger than 8Mb...
You need the Engine run signal and a relay to get a "D+" positive signal.
Cheers,
David
Blizz
Postby richbee » Thu Jul 06, 2023 4:32 pm
Blizz wrote:Can`t attach it as it's bigger than 8Mb...
Cheers,
David
I got mine on my Custom from a connector block under the driver's seat, next to the battery.
I would be surprised if it is so different for the Mk8 but I don't know for sure.
Ford do sell a special connector lead at a ridiculous £50 - and you have to be careful as there are different versions with slightly different connectors - I ended up crimping a small connector and pushing it into place - works a treat with my Ctek B2B charger
richbee
