Is there a roof vent available to fit Mk8 minibus sunroof?
Postby johnporter11 » Thu Aug 08, 2024 7:48 pm
Has anyone found an opening roof vent that will fit in place of the Mk8 minibus escape hatch?
johnporter11
Re: Is there a roof vent available to fit Mk8 minibus sunroo
Postby dumper » Thu Aug 08, 2024 8:13 pm
Hi John when I was building mine I searched for quite a while but couldn’t find one and ended boarding it over on the inside as I ran out of time if you do search on the forum and I’m sure someone on here found one that will fit after I’d finished mine
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby johnporter11 » Fri Aug 09, 2024 10:42 pm
Found it. You had a post on it. I PM'd him but no reply yet. You know, I'm having second thoughts on the whole thing. Mk8 roofs are too curved to attach a flat item. They'll always try to flatten the roof when tensioned up. The original minibus glass has a big curve in it.
johnporter11
Postby Redvee » Fri Aug 09, 2024 11:33 pm
On the videos I've seen where converters have fitted a maxair vent they have filled the undulations in the rooves of Sprinters etc with sikaflex till they've built it up to be level with the rest of the roof. I don't know how curved the roof of a MK8 is so this might not work.
Redvee
Postby johnporter11 » Sun Aug 11, 2024 11:11 pm
Yes, the fluting is one issue (and sometimes dealt with by using custom made spacers), but the general curve of the roof is what I'm worried about. In any case, I'd prefer to use the existing aperture for the minibus escape hatch. But it's very big.
johnporter11
Postby Antiriad2097 » Mon Aug 12, 2024 3:16 am
johnporter11 wrote:Mk8 roofs are too curved to attach a flat item. They'll always try to flatten the roof when tensioned up. The original minibus glass has a big curve in it.
When I fitted a Fiamma vent to the top of my MK8 van, I cut the underlying wooden frame on the inside on a curve to keep the roof shape. On top I built up the outer edges with mastic strips then caked the lot with Sikaflex all round. Seems to be the common method from all the videos I watched on it.
Antiriad2097
Postby johnporter11 » Wed Aug 14, 2024 5:15 pm
Thanks for that. Yes, I can see that will retain the curve and prevent it from straightening the curve.
johnporter11
