Advice Needed: Buying a Transit with a Wrecked Engine?
Postby chaoticbofh » Sun Oct 20, 2024 6:55 pm
Hi everyone,
I've come across a high-spec 2019 Transit with 150,000 miles, but the engine is written off. It's priced relatively cheaply. I've found a reconditioned 2.0 engine available for around £2,250.
Would paying someone to fit the reconditioned engine be sensible, or should I avoid this idea altogether? I'm looking to build a campervan using this as a base.
Thanks in advance for your advice!
chaoticbofh
Re: Advice Needed: Buying a Transit with a Wrecked Engine?
Postby dumper » Mon Oct 21, 2024 7:06 am
I may be wrong but sounds a bit cheap to me on top of that I would expect you would need new injectors /turbo there are a lot of doggie so called engine builders out there you need to be doing a lot of checks on them before you buy one I’d put the name on here and see if anyone has used them.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
