Transit conversion good or not
Postby ellabbs » Thu Jan 30, 2025 8:37 pm
hiya i have chance of getting a TRANSIT 350 MWB C/C 100 --- 58 plate, recon engine , it looks pretty good for the year, and the recon engine sounds sweet, had egr done and has 12 months test on it mine for £1000 .
whats the opinion of campervan conversion gurus on here.. im fine with the work needed to do it... i can rebuild engines- weld-electrics-woodwork that doesnt phase me. just wanting to know if these vans are popular to be converted... its a high top.
Stuck for someone to weld youre transit .....
arches, chassis, tipper work anything
contact 07561 364042
YORKSHIRE AREA
ellabbs
Re: Transit conversion good or not
Postby jay » Fri Jan 31, 2025 5:00 pm
your biggest issue is keeping the weight down inside as its so easy to go overweight either gross or rear axle
mk1 connect tourneo
jay
Postby ellabbs » Sat Feb 01, 2025 5:48 pm
thanks for the reply , much appreciated.
the "350" relates to 3.5 ton gross doesnt it ,?. so vans 1 ton i have 2.5 ton to play with. i should come well below that .
just doing research before getting the van so i kinda have a head start, looking at conversion books, is there any thats better than others...?
YORKSHIRE AREA
ellabbs
Postby dumper » Sat Feb 01, 2025 6:13 pm
The mk6 jumbo I built basic twin birth conversion with me and enough gear on board for a couple of nights away, not fully loaded for a holiday away water gas and fuel it weighed 2725 kgs .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby bortaf » Sat Feb 01, 2025 9:19 pm
ellabbs wrote:thanks for the reply , much appreciated.
the van is over 2t empty, nearer 2.5, DEFFO not 1 TON :wink:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby MinorMatt » Tue Feb 04, 2025 1:32 pm
You might want to revise that.... you will have more like 1650kg payload (inc driver, passenger, food, water etc). And transits are not heavy compared with other vans either. Yes a MWB weighs around 1850kg.
https://archive.commercialmotor.com/art ... -mwb-trend
Postby 4x4 tranny » Wed Feb 05, 2025 12:51 pm
Hi gathered you have looked through the camper/ motorhome conversion section. check out mine and see what I've done might give some ideas.
4x4 tranny
