"Maxine" MK8 XLWB Conversion
Postby mesoiam » Tue May 13, 2025 10:42 am
For those interested I'm going to try to maintain a build thread for my camper.
2019 H3L4 transit
Converting into a four berth camper for 2 adults and 2 children.
As mentioned in the L4 350 Feasibility Check 4 berth conversion thread
This is the starting point, 2019 Trasit 350 with 147000 miles, ex ford parts van. Complete with tail lift.
The dealer said a motorbike enthusiast had bought it with the intention of converting it, perhaps for going to motorbike events or something. They must have given up or come into some money because the part exed it to a motorhome company and bought a premade one.
Luckily for me it already has additional windows on the sides and sliding door, and two skylights.
Job list:
Remove tail lift
Change passenger double to single, mount driver and passenger onto swivels
Add two second row seats for the two kids
Add folding table
Electrics, plumbing, heating (diesel probably)
Bit of a kitchen
At the back add two double beds
Toilet cubicle, probably not shower
2019 MK8 XLWB Mid Conversion
mesoiam
Re: "Maxine" MK8 XLWB Conversion
Postby dumper » Tue May 13, 2025 11:43 am
As the reply on your previous thread mine been on a 460 twin wheel is going to be heavier then a 350 keep a check on the weight as you build it mine is a simple conversion and when finished it was just over 3000 kgs
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby mesoiam » Tue May 13, 2025 12:26 pm
Cheers, once the new bumper is on and I get it emptied out, I'll have a visit to the weighbridge to get the starting point and then keep track after that.
mesoiam
Postby mesoiam » Tue May 13, 2025 12:46 pm
First big job, removal of the tail lift.
This is one of those things that was going to be easy, but took a lot longer than expected. I think I will be saying that a few times during this build.
After having some fun riding up and down with the kids, the decommissioning phase started.
The tail lift has big fat 12v supply from under the drivers seat on a 250A fuse, disconnected that, being very careful not to ground that accidentally!
There was a junction box at the back inside where the button controls all connect to, labelled up the colours and removed the cables.
Unfortunately the external buttons made a bit of a mess of the paintwork, there was a seal around them but it looks like water got in and sat regardless, and the holes were just self tapped and not painted or caulked.
I've just put some sellotape on it for now while I decide what to do. Any tips in this regard would be welcome. I'm thinking I'll sand it back, patch it from behind and touch it up so it doesn't rust further and then cover it with a decal of some description.
The tail lift system has a few cabin controls, a switch to turn off the control power to stop people playing with it, and a little light to warn you you're driving around with the tail lift down scooping up pedestrians at every corner.
After wrestling a bit with the trim, the cables were free from under the drivers footwell, got some nice holes next to the steering wheel. Maybe I'll put some siwtches in or find a way to cap them off.
Another little surpise job was the fact that the tail lift installers had cut the cable for the number plate light
Luckily they had left enough length on the plug tail that this was easy enough to undo by finding the old wire and rejoining with two crimps and taping it up.
With all that electrics sorted out it was now time to get mechanical. Had a good look underneath and gave all the relevant nuts and bolts a spray of plusgas.
Seeing as this thing it significantly heavier than me a convenient starting point would be to split it into smaller pieces.
There is a big shaft that acts as the platform hinge, this itself is stopped from sliding out by an allen bolt, so just need to remove this bolt and the pin can slide out.
Image ...Not a chance :-(
I hit it with the impact gun for about a minute and it showed no signs of moving, it was eventually just going to round out so gave up on that. Tried to hammer out the big pin which is about the diameter of a large broomhandle, cut the plastic bit off a dumbell handle to make a big drift, that wouldn't budge either. Gave up on removing the platform, it wasn't a showstopper, but the removal process would have been a lot easier if I had got the platform off.
The rest of the story was similar, a lot of the bolts were very tight indeed. Some I could get manually, some I could get moving with the impact driver. Had to get out the big mains one.
Two or three of them had to be ground off.
After much clanging the tail lift was finally free.
As you can see the bumper has a big slice missing, so that's the next job.
mesoiam
Postby dumper » Tue May 13, 2025 1:42 pm
If you’re going to fit 240 v hook up fit the external socket orvfridge vent / water tank filler neck to cover up the outside switch hole
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby mesoiam » Tue May 13, 2025 2:12 pm
It's a possibility, I think even with that hookup placement, the holes are spaced in such a way at least one would still need covered.
mesoiam
