No problems with the questions! Just hope my answers help
I bought it from this guy:
http://www.airide.co.uk I chose it because the price was right and it came with the gauges which other people make you pay extra for. I explained exactly which van I had and he sent me a kit which I fitted myself, not too difficult but..... I wish I had gone there and paid the £45 extra for him to fit it as it's awkward crawling underneath the van (remember mine is always fully loaded!) and also I found that the kit was not quite as he described in his instructions, meaning that I had to cut away part of his bracket to accommodate the LSV and also part of the LSV valve bracket itself to stop it fouling the bellows on the N/S. I also had to take the O/S upper bracket back off and drill another hole in it as it was not quite in the right place which made the bellows slightly off centre, probably wouldn't have made any difference, but I would know it was there and it would annoy me. The brake lines also need to be unclipped from the axle and I am going to need new ones made to form around the brackets.
I paid £455 which includes delivery and despite my previous comments I am very pleased with it, the gauges are in the garage out of the way and are easily pumped up with a little 12Volt tyre compressor. In the picture they are at 40PSI (takes around 1 minute to get there) but that is way too high and I think 20PSI will be about right.
Here are some pictures:
You can see where I have put some protective rubber sleeve over the brake line as a temporary fix to stop chaffing. And yes, the top bracket goes in place of the bump stops.
If you want I can take more pictures.
Cheers,
Rob
