Electrics into van ??
Postby pascoe92 » Thu Feb 12, 2009 10:38 pm
hi im putting a bed into my transit mk6 but i always want to put a screen in back wiht the bed and i have found a company thlat do computer u can put in ur car so i need electrics so i can power the screen adn computer but i also need electric to power two lights im putting in the ceiling but ive not got a clue how to sort this problem and how i can do it can someone please tell me what i need to do, how i go about doing it and maybe what parts and stuff i need to do it with and where i could find it.
i know thats alot to ask but it wud be a great help and greatly welcomes to what information anyone can give me please becaue im stuck without this information
thank you to everyone who helps me.
pascoe92
Re: Electrics into van ??
Postby Luke » Thu Feb 12, 2009 10:41 pm
if you make the ceiling lights 12v dc then you can run them off the battery, the computer and screen i'd imagine they will be 240v ac so you'll need an inverter that converts the 12v dc battery to 240v ac :D
Postby OxtonyxO » Thu Feb 12, 2009 10:48 pm
you can get 12v pc power supplies ;)
http://www.powerstream.com/DC-PC-12V.htm
OxtonyxO
Postby pascoe92 » Thu Feb 12, 2009 10:49 pm
id like all the wiring to be neat and for the screen i have this information about it :
Input I/O Ports
12V DC
Power Consumption
32W (typ.)
Power Supply
AC 100 ~ 240V ; 50/60 Hz
and for the system itself i have this:
Power Input DC 6-24V
Power Consumption 90W
any ideas ??
pascoe92
Postby OxtonyxO » Thu Feb 12, 2009 10:55 pm
looks like they will both go straight to 12v dc
OxtonyxO
Postby Luke » Thu Feb 12, 2009 10:58 pm
you may want to fit a seperate leasure battery tho so you can switch off the engine battery, then if you flatten the leasure battery you'll still be able to start the van :D
Postby pascoe92 » Thu Feb 12, 2009 10:59 pm
could u tell me how u do that one luke coz thats what im stuck on becasue id only be using the lights computer and screen then im parked up anyways so how could i fit the lesuire battery and get it all set up
pascoe92
Postby Luke » Thu Feb 12, 2009 11:05 pm
this might help :D
Postby pascoe92 » Thu Feb 12, 2009 11:10 pm
how do i connect everything up to the lesuire battery once ive done that then coz im puttin\g lights in the ceiling on switch and i was hopingi could plug the computer and screen into sockets that ill fit too any ideas
pascoe92
Postby Luke » Thu Feb 12, 2009 11:16 pm
you can connect to the + terminal of the leasure battery via a fuse (rated for the appliance) then to the plug the - side of it you can just earth it to the body of the van - but to do a nice job its better to run all your earths to the same place and then run a wire dierct to the - terminal on the battery so it gets a good connection :D
Postby dachre » Fri Feb 13, 2009 12:04 am
OxtonyxO wrote:you can get 12v pc power supplies ;)
Thought the technical section in the web site from OxtonyxO was useful.
It has battery info, votage drop and wire gauge charts, ect.
dachre
Postby Bulletguy » Sun Feb 22, 2009 8:16 pm
pascoe92 wrote:hi im putting a bed into my transit mk6 but i always want to put a screen in back with the bed and i have found a company that do computer u can put in ur car so i need electrics so i can power the screen and computer......
I'm hoping that you already have a zig unit installed?
If not then this is an absolute must.....before even dreaming of any bedside tv or computers etc.
My van is a camper conversion which the previous owner fitted out quite well using furniture/fittings all supplied from Leisuredrive. Provision made for tv, status aerial professionally installed, cooker, 3 way fridge, 12v/240v electrics all properly fitted........BUT no Zig unit. BIG MISTAKE!!!
Anyone even starting/thinking of camper conversions should place a Zig unit at the very top of the list......with everything else following after. The first site you overnight on and you will soon see why it's so important to build everything around a zig.
Bulletguy
Postby Luke » Sun Feb 22, 2009 8:19 pm
whats so important about the zig? what does it do :?:
my 1st mk1 camper never had one and i cant say i missed it - the camper i'm building now i was going to fit one for the charging facility but other than that what else do they do :?:
also have you got any advice on which model to get :?:
cheers :D
Postby Bulletguy » Sun Feb 22, 2009 8:50 pm
Luke wrote:whats so important about the zig? what does it do :?:
cheers :D
Enables mains voltage connection which runs everything electrical in van plus charging leisure battery/s at the same time.
Invalueable if on tour.
Its surprising how quick you can drain a single 85ah leisure battery which most people generally go with.
Bulletguy
Postby dachre » Sun Feb 22, 2009 9:24 pm
I will be fitting a zig cos it was cheap but if i had the money id fit a CBE electrical system as it does all that my zig can do plus all of my other sensors and switches as well, plus its a tiny compact unit.
http://www.wildaxmotorhomes.com/cbe-pc2 ... m-i17.html
This is the zig model i have, its a cf9.
http://www.leisureshopdirect.com/carava ... arger.aspx
The one good thing about this unit is that is has 12v/240v outlets for the fridge that i use.
I dont think a zig unit is any better than any other electical control unit but it should be a whole lot better than nothing at all. But then its all new to me..... :lol: ......
dachre
