Hi, i am going to start making units/cupboard for my self build camper at the weekend, what is the best stuff to use to make them from, ideally i would like a beech finish, are pre built kitchen cupboards an option?
prebuilt kitchen units are not an option they are too wide. You need to have something around 16 inches wide. Old caravan units is one option the other is build your own
You could have a look at the likes of wickes as they do a budget kitchen range, you could have a look to see what you think, as if you go for the base units you could cut them to the depth you require for you hob / sink and to the shape of your van as well, but go for the full height door as i don't think you will get the draws to work.
you can buy furntiture board in any colour and thats what the pros use but u have to edge it? you could make a lightweight frame for the whole job out of slats or 2" x 2" then clad it with laminate flooring as i did(looks amazing and u can have any shade being laminate) but i havent seen yet how heat/damp/cold is going to affect the neat laimate yet over time....
235 bhp diesel skyline intercooler/nitros/chip/decat/powerflow zorst/induction kit loony camper van! now sounds like darth vader breathing and a scoobies arse end...
oh yeah......i bought a complete caravan for £140 and ripped out what i could that helped and all i did was update the wood fronts with new laminate hear and there so some of the frame work was kinda done already?
