do i need insulation under the floor?
Postby Bigredbus » Sat Jun 13, 2009 11:23 am
Hi im nearly ready to put the ply floor in my camper project but when i took the floor out of my old van it had insulation under it do i need insulation on the floor under the ply?.If i do whats best to use at a reasonable price the insultion in the old van was just loft stuff but it was only running through the lower grooved bits on the floor any advice would be great thanks luke
viewtopic.php?f=58&t=45392
viewtopic.php?f=4&t=45326
Bigredbus
Re: do i need insulation under the floor?
Postby Village Dave » Sat Jun 13, 2009 9:34 pm
I think I would put something on the floor,
I ve seen vans with kingspan/celotex on the floor first, but you loose at least 1 inch,
Its a big area to loose heat from,
I ve gone for a good quallity carpet underlay, straight on the floor then ply, I'm sure its got some insulation propeties, and helps with sound proofing aswell,
another option I was looking at was multifoil roof insulation, but its very expensive for a roll, & I could not find any lying around
suppose a couple of layers of the thin stuff that goes under laminate floors might be ok dont think it has much insulation properties though
just some ideas
Village Dave
Postby zaphod79 » Sat Jun 13, 2009 11:45 pm
Ive used roll mat in the past, this time around i used laminate floor underlay (The silver stuff) I placed a damp proof layer over all of that, before i put in a wooden floor that i covered in vinyl last time, but have yet to put a covering on the new van yet.
Ford Transit 2.4 TD 00(X) LWB med roof 350
See my camper van progress so far viewtopic.php?f=58&t=45397&p=404672#p404672
zaphod79
Postby GBBiker » Sun Jun 14, 2009 12:24 pm
I would first bitumen the steel floor to waterproof it (just in case).
I've seen people use 3/8" (10mm to the young 'uns) thick polystyrene sheet. You can get this stuff from places like Selco or Jewsons in 8'x4' sheets (2.4m x 1.2m kids :wink: ).
I've also seen, as above, foil cased laminate floor underlay used.
I wouldn't use Celotex as, contrary to popular belief, it will fall apart if it gets wet (trust me, I'm a Property Developer and I've had many arguements with Building Inspectors over that crap stuff!).
GBBiker
Wrong Again!
Postby jacka » Sun Jun 14, 2009 12:35 pm
hair felt 60oz best sound proof you can get plus it takes the shape of floor i have been in flooring 25 years always used it years ago i used 2 stick it on my mk2 escort bonnet what a difference bonnet weight a ton any carpet shop will have a half roll about cheers,jacka
jacka
Postby zaphod79 » Sun Jun 14, 2009 11:24 pm
GBBiker wrote:I would first bitumen the steel floor to waterproof it (just in case).
I did this first too
zaphod79
