Help with Camper cupboards
Postby Burgman » Sun Jul 19, 2009 12:00 pm
Help !!!!!!!!!!!!!
I'm in the process of replacing the back panel / cross member on my Mk3 SWB camper, not surprisingly I found more rot than I hoped for / expected. The end section of the chassis where the rear spring hanger's are mounted and the end by the back wheel arches are totally gone. My question is how are the cupboards and floor removed ?, I've taken out the screws that screw the cupboards to the floor and the few I can see holding them to the van sides but I can pull as hard as I like but still no movement, are they glued in as well as screwed ? are they assembled in place or built then put in the camper ? I really can't see how they're fitted !
It's a high top Mk3 but I don't know the make of conversion, although it has HIGHLANDER on the roof
HELP !!!!
Burgman
Re: Help with Camper cupboards
Postby jnwferguson » Sun Jul 19, 2009 9:20 pm
Hi
not sure if I can help but usually cupboards are fitted by screwing through the rear top rail and front bottom rail it is possible someone has siliconed them in try to get a knife behind them at least it will show where the screws are hope this helps
cheers jim.
mk2 camper
mk2 4x4
mk2 ci travelhome camper
the devil is in the detail
jnwferguson
