KrillKill's MK2 Mini Camper
Postby KrillKill » Wed May 26, 2010 3:06 pm
Hi everyone!
This is my first post on this great forum and in this thread I will share some progress of my simple camper conversion. I have recently bought a 1983 Ford Transit and I will try to do a simple and cheap motorhome of it. I will post some pictures as my work goes on and I hope someone will find i interesting. My spelling and grammar might be a bit odd because I usually dosn't write in English (I'm from Sweden), but hopefully you will understand.
KrillKill
Re: KrillKill's MK2 Mini Camper
Postby nesbitt » Wed May 26, 2010 3:59 pm
Looks a very nice example
nesbitt
Postby madmark » Wed May 26, 2010 4:02 pm
welcome :wink:
Postby KrillKill » Fri May 28, 2010 9:24 am
nesbitt wrote:Looks a very nice example
Yes, it's nice, no corrosion at all.
madmark wrote:welcome :wink:
Thank you!
Here I haved covered the holes in the back doors with thin plywood.
KrillKill
Postby KrillKill » Mon May 31, 2010 7:27 pm
The fitting of the new floor plywood.
I used OSB-Plywood because its cheaper.
Old carpet.
Removing old floor, carpet, anchor loops.
Cleaning the floor.
Cutting the OSB-Sheets.
Fitting and drilling holes.
Filling the holes where the anchor loops have been mounted.
Cutting screws and attach the sheets.
Finished, ready for the laminate floor.
KrillKill
Postby KrillKill » Mon May 31, 2010 7:40 pm
I have painted the inside of the van white, and it looks and feels much better.
KrillKill
Postby Luke » Mon May 31, 2010 7:51 pm
wow very nice 8) 8)
Postby KrillKill » Fri Jun 04, 2010 9:33 am
Luke wrote:wow very nice 8) 8)
Thanks, the white and orange goes well together.
Here's some progress on the laminate floor.
Calculate to get i right.
Think before cutting, you only get one chance.
Starting to get somewhere.
Taking a break with coffee and some reading.
The last pieces.
Done!
KrillKill
Postby projectzip » Fri Jun 04, 2010 11:43 am
loving this one.
Mk2 is my favorite style!
My Race Support Vehicle / Camper Project www.exit13.biz one off graphics to full race car livery's.
projectzip
Postby KrillKill » Mon Jun 07, 2010 10:35 am
projectzip wrote:Mk2 is my favorite style!
Yes, cool vehicles :)
I have mounted some sheet metal skirting-boards by the doors, this will prevent dirt and damp to get under the floor.
From the sheet-metal worker.
Back door, before fitting.
Back door, after fitting.
Side door, after fitting. In this picture you also see the skirting-board on the wall against the seats.
KrillKill
Postby madmark » Mon Jun 07, 2010 10:37 am
:shock: to find a mk2 in that orginal condition is very rare :shock: what a find :wink:
Postby KrillKill » Mon Jun 14, 2010 9:10 am
madmark wrote::shock: to find a mk2 in that orginal condition is very rare :shock: what a find :wink:
I was lucky to find it so close to my home (I live out in nowhere).
I have been working on the windows lately, time consuming and boring.
Here's some pictures.
Old stickers on the back window.
Window cleaned from stickers.
The small windows didn't have any rubber seal.
Mounting the rubber seal.
Removing old window tint.
Removing the glue from the window tint.
Windows cleaned and started with new darker tint.
Several days of hard work, cleaning and tinting, finally done!
KrillKill
Postby KrillKill » Thu Jun 24, 2010 9:05 am
I'm done with the grinding and painting on my roof rack.
Here are some picture of the work.
Before grinding.
After grinding.
After grinding.
Black metal paint, Hammerite.
Painted.
I had to paint it once more after it was mounted, painful.
Finally done.
KrillKill
Postby KrillKill » Mon Jul 19, 2010 9:27 am
It's been a while since my last post but I've haven't had much time to spare.
The work on the van is going quite well and I will post some pictures more regularly now.
Good news, I found an Eberspächer Gasoline Heater mounted under the van.
My brother help me get it running and I have installed heater pipes to the back of the van.
If you do not have the right tools you are in for a lot of extra work :?
Lots of small holes become one big hole.
Pipe that will go through the floor.
Sealing with silicone.
In place and secured.
The curved pipe that will connect to the heater.
Warm air outlet.
KrillKill
Postby projectzip » Thu Jul 22, 2010 10:41 pm
You lucky bugger!!
A Sweet Mk2 with a heater!
JEALOUS
projectzip
