Good Start, Bad End, Where to look?
Postby Discobandit » Sat Jul 31, 2010 6:37 pm
First outing in the machine today. Manchester to Woolley nr Wakefeild for a dog meeting. Got there no problem, ran sweet as a nut.
Used the day to check out awning and systems.
Everything fine.
Set off back home this evening, first junction thought I heard a clunk as I hit the brake. Pulled away. A faint Knock, knock, knock etc. sounded like it was wheel area but couldn't pin point where. Then it stopped. Took it easy on the way home then about a mile to go, braked. Knock, knock, knock etc but much louder:(
Again sounded like wheel area. No adverse driving problems until I turned into the drive. When I got to almost full lock the power steering started to judder as if trying to force the steering the other way.
Sat on the drive turned to both full locks and it happens both ways.
Would the knocking and power steering judder be interlinked. Or am I way off the mark?
I'll post the querie in the tech section as well and hope you good people can help.
Cheers
Gary
Disco SlowImageLurchers FastImage1997 LWB 2.5DImage
Discobandit
Re: Good Start, Bad End, Where to look?
Postby Discobandit » Sun Aug 01, 2010 10:08 am
Discobandit
