Swivel Drivers Seat Mk6
Postby Andy G » Mon Sep 19, 2011 9:01 pm
How do you guys get around the handbrake using swivel seats for the drivers seat, on the Mk6 also is the battery a problem?
Andy
Andy G
Re: Swivel Drivers Seat Mk6
Postby northernlad » Tue Sep 20, 2011 11:04 pm
The handbrake must be dropped for the drivers seat to swivel, we use the "PROMECH" or MAPA swivel bases which means battery box stays where it is and the plate bolts between pedestal and seat runners. PROMECH is the cheapest option at around £60 but a bit of fabrication required to make it work, MAPA, SCOPEMA, FASP, or SPORTSCRAFT are dearer but plug and play. Ring Autocraft in Stavely for a price first and then call JENNINGS CVS and haggle over the phone with them! If you want to be robbed / raped call Grass Routes Leisure , or if you need to remortgage call TORBAY conversions. Hope that helps.
northernlad
Postby wd60 » Mon Oct 17, 2011 5:10 am
Is it possible for someone to explain how exactly the handbrake is lowered please?
I can see how it's bolted to the side of the battery box, but how does it get secured lower down?
As you can possibly tell, I'm wanting to fit a seat swivel to the drivers seat.
Thanks in advance for your help.
wd60
Postby northernlad » Mon Oct 17, 2011 7:41 pm
Nornally it does not get lowered, we ask customers to put the vehicle in gear , drop the handbrake, swivel the seat and then put the handbrake back up - Westfalia factory Transits work in the same way
northernlad
Postby wd60 » Mon Oct 17, 2011 10:52 pm
northernlad wrote:Nornally it does not get lowered, we ask customers to put the vehicle in gear , drop the handbrake, swivel the seat and then put the handbrake back up - Westfalia factory Transits work in the same way
Really? Simple as that?
Many thanks
wd60
Postby frank133 » Sun Oct 23, 2011 6:25 pm
My van is 1990 the swivel bases were a ford part,many years ago,
I also have to take the handbrake off to swivel the drivers seat,
Its put it in gear hand brake of while keeping foot on brake pedal,
It helps if your a contortionist.if I dont do it this way it usualy rolls off the leveling ramps.
I am in the process of changing the old saab seats,for Lexus electric seats,the seat bases were adapted to fit the swivel.
But the seats are too high,so I have removed the swivel bit and my son is going to cut 3" off them.
I think its going to be worth the hassel,they are boss looking half leather seats.
frank133
Postby wd60 » Mon Oct 24, 2011 1:46 pm
Okay, I've just checked my seat/handbrake relationship, and there is no way I would be able to swivel the seat just by not having the handbrake in the UP position.
For info, my campervan is a 2005 reg LWB Hi-Top conversion, rear wheel drive.
So...............I'm still looking for info on how to safely lower or change the physical position of the handbrake lever...befoe I invest in another seat swivel.
wd60
Postby frank133 » Mon Oct 24, 2011 7:26 pm
I have fitted the Lexus seats today ,and they tend to stick on the handbrake,they will swivel
I am going to look into moving the handbrake a few inches to the left.
the Saab seat looks a bit dejected,but they will live on in my sons workshop,
This is how they look in the van,
Just the leccy to wire up to the seats and its job done,
frank133
Postby northernlad » Mon Oct 24, 2011 11:57 pm
Not sure what swivel plate you are using but it caused us no issues. Give Jennings CVS a call they will advise you on the best swivel plate to use. Tel: 01270 257417
northernlad
Postby ajpmsport » Sun May 20, 2012 5:00 pm
Hi just reading through the pages ready to get some ideas. When the seat is swivelled i asume it will miss the steering wheel ? and what happens to the lower anchor point of the seat belt ?
THANKS
ajpmsport
Postby andy 63 » Sun May 20, 2012 9:05 pm
ive posted before on this but at the risk of boring you :D ill post a few pics again. i fitted mapa swivels on my mk7. i lowerad the h/b to the floor on a bracket and moved the seat belt mounts on to the seat plinth. (welded in a capctive nut. )my bracket inclines the h/b by about 10deg and i can rotate the seat with the h/b on. a friend had his lowered by a garage and ill post that pic as well. his is still attached to the plinth. one final thing ill mention, i made a bracket for the underside of the van as well just to keep the h/b cable clear of prop shaft and exhaust. ta andy
friends job.
mine
my seats
andy 63
Postby dazaaclass » Mon Dec 01, 2014 6:18 pm
Hi I have a camper that was hand built and the donor vehicle was a transit well the handbrake cable has broke and I can't seem to find a cable for it anywhere the strange thing is that the handbrake lever bolts to the side of the base of the seat base could anyone please help me find out what this cable is off thanks
dazaaclass
Postby weseeyou » Tue Mar 03, 2015 9:02 pm
I was lucky enough to find a scissor type seat base on a transit in a breakers. Not sure if it was original equipment but its handy to change the drivers seat height to clear the handbrake for swiveling the seat . My seats are from a Toyota Lucida and have a swivel plate built into them and double arm rests.
I'll try post a pic tomorrow
weseeyou
Postby Brains_transit » Tue Mar 03, 2015 9:19 pm
The way is to fit the handbrake to the other side of the seat like Ake's funbus had as standard.
Brains_transit
Postby mjsroofing » Sat Apr 11, 2015 10:33 pm
Brains_transit wrote:The way is to fit the handbrake to the other side of the seat like Ake's funbus had as standard.
How hard is that to do
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
