Hi all,
re: above diagram. Relay 85 'connect to ignition positive' (on).
Could I find an 'ignition positive on' wire going to the radio, what colour would it be & could I connect the relay 85 to this ?
thanx
paul
johny transit wrote:If you take the two covering halves off the steering column you should see the ignition switch with its wires - just meter out the terminals (or I think they operate in order as you turn the key so should be easy to work out) can't remember the colour but once you find the right wire just hook up to it with a scotch lock connector.
See the van at http://www.fordtransit.org/forum/viewto ... 58&t=44950
