interchangeable parts with the MK1 or 2 transit
Ford A-series 1974 - 1982
Postby sven » Tue Jun 09, 2009 10:46 pm
will post parts we find which is interchangeable here
to get started:
timingbelt and waterpump for the 3,5 yorkengine are the same as for the 2.4 York found in a series and transit
sven
Re: interchangeable parts with the MK1 or 2 transit
Postby FredTransit » Wed Jun 10, 2009 10:51 am
Dash (Mk1 and Mk2) transit
Doors (Mk1 and Mk2)
Windscreen
Wheels are the same as Dodge 50
FredTransit
Mk2 Trannyist
Postby A0614 » Sun Mar 11, 2012 12:16 am
The old diesel alternator can be substituted with a Bosch 90amp from a 2.9 Scorpio.
This will fit straight in with just a slight modification of the pulley offset to the rear by removing/replacing some washers.
Now you will have about 30 amps charging at idle!
A0614
Postby Clarkb4u » Mon Jun 04, 2012 12:55 pm
Does the A series have the same king pins etc as the dodge 50?
Getting king pin kits for the A series is a nightmare, any help would be appreciated
Clarkb4u
Postby Sundowner » Wed Jul 11, 2012 1:08 pm
Aussie Mk2 have the same firewall/engine cover
Sundowner
Postby big gux » Thu Dec 06, 2012 12:28 am
i can supply and fit new king pins for any ford a series just give me ya axle beam and i will press ya old ones out and new ones in and i can also do you exchange units as long as your old units have not been beat too death by a diy artist with a big lump hammer :(
big gux
Postby Louisr » Wed Jan 16, 2019 11:03 pm
big gux wrote:i can supply and fit new king pins for any ford a series just give me ya axle beam and i will press ya old ones out and new ones in and i can also do you exchange units as long as your old units have not been beat too death by a diy artist with a big lump hammer :(
Bit of a long shot..Are you still around big gux and can you still supply kingpins?
Louisr
Return to Ford A-Series
