Hello all!!
New member? Post here to say Hi, tell us about yourself and your Transit!
Moderators: Luke, AlanN
Hello all!!
Postby Connect-rick » Sun Apr 22, 2012 4:50 pm
Hi guys, I'm rick and proud owner of a 56 reg tdci 75 transit connect!
Got it 2 weeks ago on bank hol Monday with 12 months mot and pretty pleased with it so far apart from one minor issue.
Battery light is on (I knew this on test drive and knocked the guy down £300) I'd already done a little research before looking at connects and knew it was a common fault. The alternator seems to be charging fine and the battery holds its charge so I'm putting it down to the harness.
On that note, does that fault normally cause the dials to drop off and also the backlight for them?
I'm hoping to get it sorted next weekend if I have time. Is it an easy DIY job?
Cheers in advance,
Rick
2006 white 75ps
EGR blank
Sony head unit, vibe slick 6x9 and ripspeed rs132 in front.
Connect-rick
Re: Hello all!!
Postby g-man » Sun Apr 22, 2012 6:09 pm
welcome m8y :) stick your problem up in the connect section :wink:
g-man
Re: Hello all!!
Postby Freebird. » Sun Apr 22, 2012 7:07 pm
Hi and welcome mate.
Time is a great healer. Unless it's a rash, then you're better off with ointment.
Freebird.
Re: Hello all!!
Postby AlanN » Sun Apr 22, 2012 7:36 pm
Hi and welcome to the forum :D
Re: Hello all!!
Postby Connect-rick » Sun Apr 22, 2012 8:57 pm
Cheers guys!
2006 white 75ps
EGR blank
Connect-rick
Re: Hello all!!
Postby transitandy » Sun Apr 22, 2012 9:33 pm
Hi m8 :)
Re: Hello all!!
Postby Luke » Mon Apr 23, 2012 9:33 pm
welcome to the forum mate :D
Return to Welcome
