Well its actually a 2005 Mk6 Petrol/LPG 260 SWB LR - 155000 miles.
Never had a transit before but used to drive then many years ago. This one seems pretty solid with minimal rust.
Converted to a camper but needs some work to tidy up the conversion.
Previous owner cut a hole in the roof, added some steel braces then bolted on a VW fibreglass HI Top roof !! Interesting but this too needs to be tidied up.
Now the bad bit, the engine runs but is clearly in need of some work - down on power and water leak from inlet manifold. But the previous owner did make that clear so my eyes are open.
My plan is to try and sort the engine first - compression check, find the cause of the water leak and go from there. Even worst case of a complete engine rebuild will probably still be OK
Few Photos as delivered.
