we have power ........... V8 power!!
Re: we have power ........... V8 power!!
Postby madmark » Thu Dec 30, 2010 3:36 pm
if i remeber the compreshion ratio with be down were the dipstic tube is as paul says :wink: if its erly p5/6 it will have rope seals :shock:
when i was into them i used the later block called the stiff block this was the type that was fitted to johno,s van! :wink:
great engine i use to get 24mpg out of mine 8) 8) and it sounded awsome!
Postby Luke » Thu Dec 30, 2010 5:36 pm
BROWNYS V6 wrote:whats the gearbox bw 35 or 65 :?:
no idea! anyone know from the pic :? or how do i tell :?:
Postby madmark » Thu Dec 30, 2010 7:58 pm
i might have to change my mind it looks strange maybe its not a bw35 :roll: were is andyg he might shed some light on it :idea:
Postby BROWNYS V6 » Fri Dec 31, 2010 11:59 pm
should be a small alloy plate on the side
BROWNYS V6
Postby madbri » Sat Jan 01, 2011 6:12 pm
madmark wrote:if i remeber the compreshion ratio with be down were the dipstic tube is as paul says :wink: if its erly p5/6 it will have rope seals :shock:
was ures a white 1 mk3 back in1992/3 at grendon underwood i think nsva :roll:
madbri
Postby madmark » Sat Jan 01, 2011 6:59 pm
no mate mine was blue :wink: dont remeber a white one ,and i hadnt seen anymore about at that time :wink: :wink:
Postby madbri » Sat Jan 01, 2011 7:03 pm
could av been blue long time ago :lol: :lol: :lol:
madbri
Postby madmark » Sat Jan 01, 2011 8:43 pm
:lol: :lol: oh yes its a wile back, it was normal blue with lights all over it ,and sounded the bollocks 8)
Postby Luke » Sun Jan 02, 2011 8:03 pm
yep - it's a BW45 :D
so is that the better one :?: :lol:
Postby Luke » Sun Jan 02, 2011 8:05 pm
other engine news - ive just pulled the plugs - they all look good 8) and the engine turns over (socket on the crank) nice and easy :mrgreen:
the dizzy is totally wrecked, shafts slightly bent and the case is cracked :( so we need one of those - so any ideas what we need (years/models) :?:
Postby Luke » Sun Jan 02, 2011 8:32 pm
missed this post - i'll have a look :D
madmark wrote:if its erly p5/6 it will have rope seals :shock:
rope seals on what?? the rocker gaskets are cork :D
Postby transitgeoff » Sun Jan 02, 2011 8:59 pm
prolly like the jag ive just done, rear mains oil seal was asbestos rope :D
transitgeoff
Postby Luke » Sun Jan 02, 2011 9:04 pm
Luke wrote: it's a BW45
actually it's not it's a BW35 - i was reading it wrong the 45 is stamped on and it's actually a 43 :oops: :lol:
still cant find the compression ratio tho :?
Postby dachre » Sun Jan 02, 2011 10:58 pm
"Rope seals" might mean the outer crankcase seals.
On older vehicles/classics these were made of a cloth material and if you parked the car up for any time (2-3 months) you would still have to rotate the crank every now and then to lubricate the seals because if they dried out they would knacker up.
dachre
Postby Luke » Sun Jan 02, 2011 11:01 pm
might have to get some new ones then :lol:
also i'll have a look for my compression tester then do a compression test on it :idea: should give us a good idea of how good it is :D
