we have power ........... V8 power!!
Re: we have power ........... V8 power!!
Postby Luke » Fri Jan 21, 2011 10:21 pm
MinorMatt wrote:whats the throat size on the carbs Luke? I suspect they are HS6 or HS8s....
i'll check next time i'm up mate :D
Postby MinorMatt » Fri Jan 21, 2011 11:24 pm
I *think* I have a HS6 somewhere
Postby sideshow_bill » Sat Jan 22, 2011 4:28 pm
Is there likely to be any issue with emissions from the V8, as it will have to comply with the registration date of the van - not the date of the engine?
sideshow_bill
Postby captain hook » Sat Jan 22, 2011 6:46 pm
Dizzy is here......Yes HS6 Matt.. 8)
captain hook
Postby Luke » Sat Jan 22, 2011 6:48 pm
sideshow_bill wrote:Is there likely to be any issue with emissions from the V8, as it will have to comply with the registration date of the van - not the date of the engine?
no when we fitted the cossy yb in the 51 plate mk6 he did the emmissions on a 1990 engine :D
Postby Luke » Sat Jan 22, 2011 6:49 pm
captain hook wrote:Dizzy is here......Yes HS6 Matt.. 8)
nice one 8) can you post it up :?: i'll cover the postage :D and does it have any plug leads with it :?:
Postby sideshow_bill » Sat Jan 22, 2011 11:44 pm
My P100 was on a Q plate 1990 registration and that used to get tested as a 1990 - even though the engine was a 2.0 pinto from a 1976 Transit. It passed but...
sideshow_bill
Postby Luke » Sat Mar 26, 2011 11:20 pm
well i've now got in my hands a dizzy and coil courtesy of captain hook 8)
i'm away for a week but when im back i'll post some pics of it all :D but we should have all we need to get it going now :D
Postby reevco62 » Tue May 24, 2011 10:46 pm
Oh no, last month I took a ton of V8 bits to the tip, rocker boxes cylinder heads, power steering pump, water pump, sump, Twin carbs and manifolds when I cleared out my old garage................. :-( Sorry
It takes thousands of nuts to hold a Transit together but only one nut behind the wheel to distribute them all over the road...
reevco62
Postby Luke » Tue May 24, 2011 10:47 pm
reevco62 wrote:Oh no, last month I took a ton of V8 bits to the tip, rocker boxes cylinder heads, power steering pump, water pump, sump, Twin carbs and manifolds when I cleared out my old garage................. :-( Sorry
nice 1st post :lol: :lol:
Postby theramraid » Mon May 30, 2011 4:37 pm
Them engine mounts on the pics.... can you buy them? who made em?
theramraid
