CLICK HERE TO VOTE ON IT
Luke wrote:took from this post![]()
what about this![]()
I AM SERIOUS
http://cgi.ebay.co.uk/TOYOTA-HIACE-SUPE ... 1c1594b0bd
extended tag axle 6 wheeler![]()
we do have 2 vans we could use- get some thick walled box section run it down the chassis rails for extra strength cut and extend the body - fit a 2nd axle drive the front axle and have the rear one just trailing, braking and suspention but not driving
can anyone knock us up a photoshop![]()
Luke wrote:i reckon the easyest way would be to use an empty (no diff or halfshafts) axle casing mounted in the same way as the front back axle - but as you say move the leafs inboard a bit - doing that shouldnt affect the stability as the front axle will be in the origanal place and still have the outboard leafs![]()
the only thing i can think of is how would you lubricate the wheel bearings on the back axle with no halfshafts or diff to circulate the oil round to themunless we weld a blank in where the half shaft should go then drill tap the top (fit a vented plug) and fill the voids with gear oil
Luke wrote:just been on the phone to martin - he suggested a mk6 fwd back axlethat would be idea
the problem with a front axle is the strut would go up into the van and we'd need to fab a top mount
TIMO wrote:Luke wrote:i think the hardest bit will be finishing the bodywork between the join of the 2 vansthats the bit we need some serious skilled men (or women
) on
- done wrong or bodged it'd spoil it
thats one big panel to get right with no ripplesthe best way would be ..if poss to seperate factory joints and extend it that way?? if we had,,lets say a spare jumbo we cut cut the extra 18 inch out of it and use that on the back of the project van,,,if you see what i mean?
TIMO wrote:TIMO wrote:Luke wrote:i think the hardest bit will be finishing the bodywork between the join of the 2 vansthats the bit we need some serious skilled men (or women
) on
TIMO wrote:how about just a stretched translimo?? excuse my photoshop skills.. may also be more sellable![]()
executivetravel wrote:RADICAL IDEA.............
return it to "showroom as new"
rebuilt mechanicals, jack it up, rip the mechanicals out >>>>>>>>>>>>> workshop
lift body onto trolley >>>>>>>>>>>>>>>>>>>>>>>>> bodyshop
havent you ever seen Chip Foose "overhaulin"?
then a few subtle touches (very few, very subtle)
redcube wrote:executivetravel wrote:RADICAL IDEA.............
I like that idea
