the tag axle wheel arch - how shall we do it?
Postby Luke » Mon Mar 07, 2011 12:10 pm
as we've got no team captain for the bodywork crew yet i'll have to start this discussion off :D
thinking about the rear arch i'd origanally imagined it to be like this :arrow:
option 1
but it might be easier if we did it like this :arrow:
option 2
for option 2 we'd only need 1 arch repair panel a side then make up the lip that joins the 2 halfs together :idea:
another thing is with option 1 there would be nothing to support the bit that stuck down between the wheels :)
anyway feel free to add ideas - what do the bodywork guys think :?:
Re: the tag axle wheel arch - how shall we do it?
Postby madbri » Mon Mar 07, 2011 12:22 pm
luke im thinking no 2!!! could u also flare wheel arch a bit so u can drop it just over the tops of the tyres??? this hidding ugly suspension + giving it the low ride look???
madbri
Postby manandvan » Mon Mar 07, 2011 1:11 pm
i think somewhere in between, no1 comes down too far, have a look at a neoplan skyliner bus rear arch to see what i mean. :D
manandvan
Postby Luke » Mon Mar 07, 2011 1:13 pm
like this :D
Postby transitgeoff » Mon Mar 07, 2011 4:03 pm
option 2 easiest by far to refinish id say :)
transitgeoff
Postby ake » Mon Mar 07, 2011 8:29 pm
Option 2 :)
Postby AlanN » Mon Mar 07, 2011 9:54 pm
I think it depends on the spacing between wheels, if their close together option 2, but I prefer the option 1 and as said, not so low... like below, but maybe a bit more pointed
Postby redcube » Tue Mar 08, 2011 11:04 pm
no 2 for me it easy to do in the time me have
redcube
Postby Luke » Tue Mar 08, 2011 11:22 pm
well i think the hiace looked pritty good like that :D
Postby Gavin » Tue Mar 08, 2011 11:42 pm
option 1 is easy with those large panels that go up to the swage line (not the arch repair pieces) a lh lower rear side panel butted end to end with rh one on one side and the reverse on the other :wink:
stretch the chassis, tub the inner arch as one unit and weld the outer panels over the outside. simples :lol:
the axle spacing would be dictated by the arch seperation but you could weld the panels up together and take measurements from them before going anywhere near the chassis......
Gavin
Postby Luke » Tue Mar 08, 2011 11:47 pm
Gavin wrote:the axle spacing would be dictated by the arch seperation but you could weld the panels up together and take measurements from them before going anywhere near the chassis......
this is why i'm asking now - i'm gonna make a jig to hold the 2 axles together while we weld on the rear most spring hangers (the front axle will stay in the origanal position) - if we go for option 2 the wheels will be closer together than option 1 :!:
i'd imagine it'll drive better with the wheels as close together as we can get them :? :D
Postby manandvan » Fri Mar 11, 2011 10:24 am
the pics alan n put on is the neoplan skyliner thing, and i think thats the best, its exactly what i had in mind when i said skyliner, didnt take long to find a good skyliner pic? lol
manandvan
Postby Luke » Fri Mar 11, 2011 10:37 am
i think basically we want the wheels as close together as we can get them (for making the jigs) :D - we're pritty much decided option 1 is a no :!: option 2 is the easyest :!: and option skyliner is the preffered one :D
what i'll do is make the jigs and we can decide later on either option 2 or option skyliner as both of those require the same distance between the wheels :D
Postby GPM01 » Fri Mar 11, 2011 3:18 pm
Option 2 for the time we have, but Skyliner looks better. Don't think we've got the time to be overly creative, more's the pity :( :shock:
If you want a real van.......You gotta get a Transit!!!!
GPM01
Postby GPM01 » Fri Mar 11, 2011 3:25 pm
Thinkin' about it, we could do option 2, then I could make some spats for it ready for Mania? 8) 8)
GPM01
