Mk8 rwd
Mk8 rwd
Postby oldyellar » Thu Mar 14, 2019 9:20 pm
Hi guys I have a mk8 rear wheel drive tipper, I've owned it from a year old it's done around 66000miles now I got it on 20000miles.
I have always serviced it every 8/10k .
It's now jumping into limp mode and the skid light is coming on and a warning on the dash saying service engine now, it was serviced a few weeks ago and before that in October 18, I've plugged it into my little generic code reader and it's coming up with a few codes.
Any ideas what I should look for? There is no smoke of any sort from the truck and turbo power is good however it can be a bit laggy
Why wasn't Rome built in a day?
Becuase I wasn't the Gaffer!
oldyellar
Re: Mk8 rwd
Postby loot » Fri Mar 15, 2019 5:40 pm
The turbo actuator is probably faulty or stuck.
07 350 170ps
Ids map here
loot
Re: Mk8 rwd
Postby oldyellar » Fri Mar 15, 2019 7:15 pm
loot wrote:The turbo actuator is probably faulty or stuck.
I think so I've soaked it with with dw40 leave it over the weekend see how it works out, looks about £150 for a new actuator plus fitting I'm not up to the job myself.
oldyellar
Re: Mk8 rwd
Postby loot » Fri Mar 15, 2019 7:53 pm
It's an arse on the rwd mk8, I think it needs getting from underneath our something or remove the turbo? I just managed to remove the circlip in situ but it pinged off somewhere :lol:
07 350 170ps
Ids map here
loot
Re: Mk8 rwd
Postby oldyellar » Fri Mar 15, 2019 8:03 pm
Alternator looks like it needs to come off :evil:
oldyellar
Re: Mk8 rwd
Postby oldyellar » Fri Mar 15, 2019 8:29 pm
loot wrote:It's an arse on the rwd mk8, I think it needs getting from underneath our something or remove the turbo? I just managed to remove the circlip in situ but it pinged off somewhere :lol:
Loot is there anyway to determine it is the actuator? Or is it turbo out and check the condition of that first to eliminate to start the process of elimination?
oldyellar
Re: Mk8 rwd
Postby loot » Fri Mar 15, 2019 9:31 pm
They are a common fault, the 2 codes mean that the actuator isn't moving, the vnt on these adjusts turbo pressure by changing the pitch of the turbo vanes basically, so the van says more boost and the actuator adjusts so the turbo boosts more and likewise it moves the other way to reduce boost, it is doing neither. You can try and look at the turbo rod and floor it to see if it moves.
You can also do a turbo test in ids.
Also side note, the 1 I looked at apparently it was a sensor on the intercooler or something so it might be a simple as that. You'll need ids and someone who is familiar with it to check it out though. I usually say the advisor is goosed but it is possible in these to be another sensor :? Unless the guy was lying :roll:
Bloody ford
07 350 170ps
Ids map here
loot
Re: Mk8 rwd
Postby oldyellar » Sun Mar 17, 2019 11:38 am
loot wrote:They are a common fault, the 2 codes mean that the actuator isn't moving, the vnt on these adjusts turbo pressure by changing the pitch of the turbo vanes basically, so the van says more boost and the actuator adjusts so the turbo boosts more and likewise it moves the other way to reduce boost, it is doing neither. You can try and look at the turbo rod and floor it to see if it moves.
Also side note, the 1 I looked at apparently it was a sensor on the intercooler or something so it might be a simple as that. You'll need ids and someone who is familiar with it to check it out though. I usually say the actuator is goosed but it is possible in these to be another sensor :? Unless the guy was lying :roll:
Bloody ford
I'll ring Dan t he's not far from me he's probably the best bet
oldyellar
Re: Mk8 rwd
Postby oldyellar » Wed Mar 27, 2019 8:51 pm
Turned out to be the electronic actuator cost £150 to repair
oldyellar
Re: Mk8 rwd
Postby loot » Wed Mar 27, 2019 9:11 pm
That's not bad for a mk8 since they're in a cnut of a location from what I could see.
Mk7 rwd was a 5 minute job.
07 350 170ps
Ids map here
loot
Re: Mk8 rwd
Postby oldyellar » Sun Mar 31, 2019 2:33 pm
loot wrote:That's not bad for a mk8 since they're in a cnut of a location from what I could see.
Repair was done by a Ford technician "on the side" so would probably cost more in most situations .
I'm over the moon :D
oldyellar
