Can you name this pattern?
Postby Funkyjazzlover » Sat Jan 09, 2021 3:40 pm
I'm going to be looking for a replacement passenger seat in the near future (going from double to single) and want to make sure the front seats match. As the probability is the seat will be coming from Europe I'd love to have a concrete ID for the fabric pattern to limit the opportunities for mess-ups. So far I've not had any luck identifying it.
Does anyone know either the name or code for this seat pattern? Cheers!
Funkyjazzlover
Re: Can you name this pattern?
Postby Frag » Sat Jan 09, 2021 4:52 pm
Post or pm your reg number and it will tell you that on ETIS,material and pattern
Frag
Ford Technician
Postby Funkyjazzlover » Sat Jan 09, 2021 6:12 pm
Frag wrote:Post or pm your reg number and it will tell you that on ETIS,material and pattern
Brilliant - thanks.
Funkyjazzlover
Postby ChallengeAdventures » Sun Jan 10, 2021 11:02 am
You can just look on Etis yourself, all you need is VIN or Reg number.
Easy to do rather than waiting for someone else to do it.
https://www.etis.ford.com/vehicleRegSel ... .ito034586
ChallengeAdventures
Postby Frag » Sun Jan 10, 2021 1:25 pm
It doesn’t tell you that info unless you are registered or logged in,only basic spec.
He hasn’t posted his reg so I can’t look it up,and I’m not sure he’s able to PM being a new member (hence telling him to post his reg)
Frag
Ford Technician
Postby Funkyjazzlover » Wed Jan 13, 2021 9:25 pm
ChallengeAdventures wrote:You can just look on Etis yourself, all you need is VIN or Reg number.
I joined ETIS. Bit of a nightmare to navigate, but got there in the end.
Found out the pattern is called Traxom on charcoal black.
Funkyjazzlover
Postby ChallengeAdventures » Sun Jan 24, 2021 9:33 pm
Sorry Frag did not realise you needed to be a member to see everything.
Do you get charged for joining and seeing info?
ChallengeAdventures
