Water INGRESS loom short, injector short, suspect Ecu fault
Postby George Lamm » Wed Apr 14, 2021 7:42 pm
Hi all,
I could do with some advice and help.
I'm a new owner of a 2016 transit 350 125hp lwb H3 90k miles.
Bought from a dealer and 10 days in it broke down and AA recovered me to a garage.
Codes:
P250C00 - engine oil sensor
Short to B+.P126200 - injector cylinder - engine malfunction
The dealer is being helpful and wants to be sent quotes for the fix.
Spoke to the garage today and they are saying water damage to the loom, the No2 injector is suspected to have been shorted, and a fault has been traced to the ecu sending pulse messages causing the van to going into limp mode and miss fire.
Hope that makes sense. This is my first van and I've had the luxary of not needing a vehicle for 7 years. Was nervous about this big purchase, biggest investment as i am just starting out on my own, it took me 2 months looking.
How can I make sure this will be the right fix? Or should I consider returning the van and start looking for a van again?
Any advice would be much appreciated
Regards
George
George Lamm
Re: Water INGRESS loom short, injector short, suspect Ecu fa
Postby Willber37 » Wed Apr 14, 2021 11:03 pm
Water ingress would suggest that water is finding its way through the scuttle trim, have a read of this : https://fordtransit.org/forum/viewtopic.php?f=64&t=205472
I would make sure it has the upgraded parts as mentioned in that thread, physically test to see how water is getting through in the first place. Water can slowly get through the very middle of my scuttle,.. I'm trying to decide whether to weld it shut with Sikaflex or not. Such a poor design.
Hope you get it sorted, pretty bad luck.. at least you bought from a dealer!
Willber37
Postby George Lamm » Thu Apr 15, 2021 8:30 am
Willber37 wrote:Water ingress would suggest that water is finding its way through the scuttle trim, have a read of this : https://fordtransit.org/forum/viewtopic.php?f=64&t=205472
Thanks. Yeah bit of bad luck tbh. Spoke to a local Ford transit centre in Hertfordshire they can see the van until 3 weeks. I have 15 days left to decide whether to do the fix or drop it back to the dealer.
George Lamm
Postby George Lamm » Sun Apr 18, 2021 10:29 am
I am returning the vehicle back. Only options available are 2.0 ecoblues
George Lamm
