Do I need a radio code ? Disconnecting battery
Postby Digahole78 » Thu Apr 22, 2021 2:32 pm
Hello all. Need to disconnect battery to weld a couple of bits. Can anyone tell me if I will need a radio code or anything else to be aware of when disconnecting battery?
Many thanks
Digahole78
Re: Do I need a radio code ? Disconnecting battery
Postby cornishpasty » Thu Apr 22, 2021 7:09 pm
You can fit another radio without coding so disconnecting battery should be fine
cornishpasty
Postby Digahole78 » Thu Apr 22, 2021 7:53 pm
cornishpasty wrote:You can fit another radio without coding so disconnecting battery should be fine
Thank you. Much appreciated
Digahole78
Postby dumper » Thu Apr 22, 2021 9:33 pm
Yes will be ok when I was building my van had them off many time and after fitting new batteries no need to enter a code.
Postby Digahole78 » Fri Apr 23, 2021 7:49 am
dumper wrote:Yes will be ok when I was building my van had them off many time and after fitting new batteries no need to enter a code.
Thank you Dumper. Much appreciated
Digahole78
