Timing belt recall
Re: Timing belt recall
Postby sparkie1984 » Wed May 12, 2021 6:08 pm
Wow, thanks for the heads up. I’m getting paranoid about my 2018 Custom now…. It’s only done 22,000 miles but that’s irrelevant to the belt condition I’d guess?
sparkie1984
Postby Chrisp74 » Thu May 13, 2021 1:41 pm
p2thed wrote:Just a side by side comparison of the old belt(heavily deteriorated)and the new recall belt and part number,if anyone is changing theirs. If any one is going to do it themselves then the sump pan must come off, the oil strainer was completely chocked with belt fragments.
Fantastic, thank you. Very useful to see a "bad" one. I carried out the inspection myself for peace of mind until the Ford inspection becomes available. On my belt the writing was clearly legible with no delamination of the belt visible.
Could you comment on the mileage and servicing of the belt in the image?
Chrisp74
Postby p2thed » Thu May 13, 2021 2:49 pm
2018 plate with around 88,000 on the clock. Serviced at around every 25,000 miles each year.
p2thed
Postby Chrisp74 » Thu May 13, 2021 9:32 pm
OK, so 3 oil changes in 88k. Full service history I guess!
So in this case either the belts going to snap or the oil pick up is going to block before the cambelt is due!
Chrisp74
Postby p2thed » Mon Jun 07, 2021 6:33 pm
Timing belt recall has just been re-released.
p2thed
Postby Chrisp74 » Mon Jun 07, 2021 7:04 pm
Thank-you! Hopefully get it booked in ASAP!
Chrisp74
Postby Chrisp74 » Mon Jun 07, 2021 7:07 pm
p2thed wrote:Timing belt recall has just been re-released.
Do you expect the recall to show on ETIS?
Chrisp74
Postby sparkie1984 » Mon Jun 07, 2021 7:07 pm
Just checked Etis and my 2018 custom isn’t due a recall apparently
sparkie1984
Postby p2thed » Mon Jun 07, 2021 7:42 pm
it was released on 6/6/2021, more than likely it will be a gradual release to customers as not to cause a parts supply shortage again.
p2thed
Postby Chrisp74 » Mon Jun 07, 2021 8:22 pm
Understood. Thanks.
Chrisp74
Postby sparkie1984 » Mon Jun 07, 2021 8:24 pm
Makes sense
sparkie1984
Postby austieman » Thu Jun 10, 2021 11:04 pm
Thanks p2thed! Just checked mine and the recall notice has been relisted on ETIS.
If anyone is interested, the guys over at Salvage Rebuilds UK on youtube have just finished a timing belt change on a transit custom 2.0l ecoblue and frankly it looks like a nightmare. https://youtu.be/lxrxzkG4PXk
Mk8 L3H3 2.0L
austieman
Postby austieman » Mon Jun 21, 2021 10:02 am
Just wondering if anyone on here has taken their van in for the recall yet and actually had the timing belt changed? I'm about to book mine in.
Mk8 L3H3 2.0L
austieman
Postby sparkie1984 » Mon Jun 21, 2021 10:29 am
Mines not showing as due, what year is yours?
sparkie1984
Postby austieman » Mon Jun 21, 2021 11:38 am
sparkie1984 wrote:Mines not showing as due, what year is yours?
2016. It's also at the 80k mile mark which seems to be when the belt issues start to crop up based on what I have read.
Mk8 L3H3 2.0L
austieman
