Hi guys, I have been offered a Mk8 66 plate Transit 350 L3 H2 RWD 2.2TDCI (125psi) Van.
It has 133k on the clock and has had a replacement engine sometime in the last couple of years that had only done 20k.
In the last month or so It has started to lose coolant internally. Apparently they have to top it up every couple of weeks and apart from that it drives fine and doesn't overheat.
They don't want to spend anymore money on the van and are changing to small ones.
Any ideas what the problem could be and if it may be a cheap/easy fix and an idea of cost.
Or do I run a mile??
