Engine Service Now
Engine Service Now
Postby Wellies » Mon Aug 02, 2021 4:03 pm
mcbutler wrote:Had my jumbo Mk8 for around 7 months now and during that time I have had a recurring error appearing.
The notification I get whilst driving is in the photo, the van also goes into limp mode and 'hill start assist' is indicated as no longer available.
The problem invariably occurs over 50mph when going uphill and/or negotiating a left hand bend.
Error clears after engine restart
Can anyone shed any light on this?
Mine is doing similar, uphill and the left hand bend thing.
I have 2 Error codes P0045 and P00BD, the first being Boost control solenoid A circuit open and the latter is ( I believe ) MAF related.
Would be interesting to see if you had same error codes.
Wellies
Re: ENGINE SERVICE NOW
Postby Wellies » Tue Aug 03, 2021 10:30 am
Update.... Been to see mechanic friend and he's found a hole in the intercooler hose ( right hand side under engine ).
It seems to have rubbed against the subframe and over time has produced a hole.
Hose on order, will update when fitted and tested.
Wellies
Postby Wellies » Mon Aug 09, 2021 3:01 pm
Update on my similar problem, hose fitted and all sorted. Flying up the hills and no dreaded messages... Bliss.....
Wellies
Re: Engine Service Now
Postby Suggs » Tue Aug 10, 2021 8:01 pm
Had this today with my 2015 350
Driving normally when amber service now message appears and goes in to limp mode, pulled over and switched off then re started and back to normal. Drove a further 70 miles with no problems, got home plugged reader in and no codes stored : /
Suggs
Postby mcbutler » Thu Aug 12, 2021 9:00 pm
Got three error codes - 3 glow plugs are open circuit, not too bothered about that
Posted photos below if anyone knows what they mean.
2014 Mk 8 Jumbo 350 2.2 RWD single rear wheels
mcbutler
Postby BerkshireVanCentre » Sun Aug 15, 2021 9:31 pm
Have you visibly checked the boost pipes for any leaks? Do the indicators work?
BerkshireVanCentre
Postby KevofCov » Wed Aug 18, 2021 8:18 pm
Hmmmm sounds very simular to an issue I had;
viewtopic.php?f=64&t=192762
KevofCov
Postby mcbutler » Sun Aug 22, 2021 5:53 pm
Hi all,
Finally managed to creep underneath her today.
On the drivers side of the engine I discovered oil seepage from a hose that runs from the valve cover to the hose feeding air into the turbo (see photo) the hose is shielded with a thick corrugated foil like material.
Another oil leak is present where the turbo inlet hose has a short corrugated rubber hose connecting it to the turbo.
So your thoughts on the parts indicated with red arrows
And part numbers or names for the 2 hoses indicated by yellow arrows if possible
Thank you all for your help
mcbutler
Postby somename » Tue Jul 14, 2026 9:56 pm
Hello,
Have a same issue, and wondering if rhere any updates to this thread as last post was 2021 and now we are 2026.
Thank you
2016 Ford Transit 350M series Mk 8 Jumbo 2.2L CR TC 14 DSL 125 PS, RHD RWD, High Top, L2H3.
somename
