Error P060A
Re: Error P060A
Postby Wesleymk8 » Wed Jul 08, 2026 1:51 am
metalworker0 wrote:It would if there were two circuits down in the barrel
and read this post .. read the last one
viewtopic.php?f=64&t=224514
wondering if just pulling things apart and putting them back together cleaned up a pin or a fuse socket
Sent you a pm btw.
Wesleymk8
Re: Error P060A
Postby andz327 » Fri Jul 31, 2026 3:39 pm
just a thought.... when you cleaned starter cables i assume you put the 2 heavy red cables (starter to alternator and fuse box to starter) back on the solenoid and earth strap back on starter securing bolt
sometimes people seem to leave one of the red cables off
andz327
Re: Error P060A
Postby Wesleymk8 » Mon Aug 03, 2026 9:24 am
andz327 wrote:just a thought.... when you cleaned starter cables i assume you put the 2 heavy red cables (starter to alternator and fuse box to starter) back on the solenoid and earth strap back on starter securing bolt
Yes all cables went back on, still trying to fix the bloody thing.
Wesleymk8
Re: Error P060A
Postby andz327 » Tue Sep 01, 2026 1:45 am
tell me your sorted now ?? actually just sounds like a blown fuse or fuse put back in wrong position when you've been doing the AC problem
andz327
