P0299-P Engine service now - 2015 Transit 2.2 460
Postby SuperMari0 » Tue Sep 15, 2026 4:21 pm
Vehicle is a Ford transit 460 2015 2.2 Euro 6
Getting error codes:
P0299-P Turbocharger/Supercharger Underboost
P0299:00-E4
I have had:
This seems to happen when i'm running at speed on the motorway or going up hill. It rarely happens while driving at normal speeds.
I'm not sure what else to do
SuperMari0
Re: P0299-P Engine service now - 2015 Transit 2.2 460
Postby metalworker0 » Tue Sep 15, 2026 5:09 pm
This fault could also be caused by stuck open EGR valve
Postby SuperMari0 » Wed Sep 16, 2026 4:18 pm
Seems like the error code P0299-P Turbocharger/Supercharger Underboost is causing the DPF to fill up.
DPF doesn't seem to be regening now because of the code. Vehicle is used on the motorway majority of the time
SuperMari0
Postby metalworker0 » Wed Sep 16, 2026 4:29 pm
Yes, any leak, EGR or boost leak, will cause it to run rich and smokey and clog the DPF.
Postby SuperMari0 » Wed Sep 16, 2026 4:36 pm
metalworker0 wrote:Yes, any leak, EGR or boost leak, will cause it to run rich and smokey and clog the DPF.
I've been watching a few videos and I'm thinking about getting the injector seals replaced, EGR valve replaced and MAP sensor replaced while checking the wiring to it. 2 boost pipes have been replaced already but I think there is a third one too that could need replacing just to be on the safe side.
i'll let you know how it goes.
SuperMari0
Postby metalworker0 » Wed Sep 16, 2026 4:51 pm
Before spending your money you need to look on a diagnostic scanner, preferably Forscan and observe if:
EGR actual in percent readings are following EGR commanded in percent, this is in "real time" "live data" mode.
The EGR will be the first thing to let you down, a sticking EGR is a service item that should be never overlooked, in service it will become blocked with carbon and needs to be cleaned out as often as; every 20,000 on some vans if they are subjected to short runs.
NOTE: An EGR that isn't cleaned often can break the plastic gears in its actuator gearbox- this can lead to a many puzzling diagnostic sessions.
Other places for leaks .been reported here. not sure what configuration rwd or fwd .. is the boost pipe can develop a leak near the alternator, where it rubs on a bolt.
Cheap scanners do not do real time live data.
Forscan is free to download to a laptop .. you just buy the "Vlinker" cable
Postby SuperMari0 » Thu Sep 24, 2026 9:17 am
metalworker0 wrote:Before spending your money you need to look on a diagnostic scanner, preferably Forscan and observe if:
I used Forscan to check my EGR readings at idle and while driving. An AI analysis of the screenshots confirms the EGR is sticking, so I'm getting it replaced this week.
SuperMari0
Postby metalworker0 » Thu Sep 24, 2026 4:06 pm
Well depending on your driving style, at worst, you'll be asking a garage to replace it every 20,000, that's if you are not learning to take it apart and clean it .. if garage bills are small compared to your income .. then no worries.
Postby SuperMari0 » Tue Oct 06, 2026 3:59 pm
metalworker0 wrote:Well depending on your driving style, at worst, you'll be asking a garage to replace it every 20,000, that's if you are not learning to take it apart and clean it .. if garage bills are small compared to your income .. then no worries.
I changed the EGR and cleaned out the inlet manifold but still got the error.
I have since cleaned the intake pipe and changed the MAP sensor. see how it goes.
SuperMari0
Postby metalworker0 » Tue Oct 06, 2026 5:15 pm
The next thing to look at is the turbo .. this has a variable vane actuator
Two things to go wrong here.
The vanes are carboned up and stuck .. or the actuator gearbox is busted or both
I see in this picture here that there is a link rod from the gearbox to the turbo
https://i.ebayimg.com/images/g/0DkAAeSw ... l1600.webp
in forscan there is a page to test that the link rod is working the vanes ..
from google AI .. because i have no idea how to steer you to where forscan turbo test is
So alternative for now .
Ignition Self-Test: When you turn the ignition key to the ON position (without starting the engine), the electronic turbo actuator typically performs an automatic initialization sweep. You can watch the actuator arm move from its rest position and return to verify that the internal motor and circuit are responsive............Try that first
The temporary cure is spraying turbo vanes with carb cleaner .. or is disassembly if vanes stuck
or replacing the gearbox if the vanes sticking, has busted the gearbox ...gearbox is called the actuator
If above is found working. it could be still sticking
Then you need to look at forscan in real time (LIVE DATA), whilst driving .. to see if turbo actual in percent is following commanded in percent
with ACT and CMD pids or pids with those initials on them as part of their name and relating to a turbo pid . note percent .. we don't want "steps" .. as that will have you doing some maths
Postby SuperMari0 » Tue Oct 06, 2026 9:22 pm
metalworker0 wrote:The next thing to look at is the turbo .. this has a variable vane actuator
The turbo is 2 months old. Could it still be the problem?
I need to test the vehicle with the new MAP sensor.
SuperMari0
Postby SuperMari0 » Thu Oct 15, 2026 7:55 pm
I've tested the vehicle but the bad news is i'm still getting boost problems.
Now I've got new codes as well:
P0045-P - Injector Leak(INJIL).
P0045:00-25 - Turbocharger/Supercharger Boost Control 'A' Circuit / Open
SuperMari0
Postby metalworker0 » Thu Oct 15, 2026 8:27 pm
Same again, check actuator is working with commanded / CMD and actual /ACT pids following each other in real time --- live data
Then see if its actually moving.
So something is wrong with the actuator or the wiring,
all i can do is look up these codes .. as you have,
Both fault codes say the same //"P"means its a pending fault code
There Should be an actuator test in forscan .. not sure if you need the licence to use it.
Postby MagsH72 » Wed Oct 21, 2026 10:26 pm
I'm afraid I'm no mechanic, but I've been following this one with interest... oh dear, it does sound like a right saga. Does anyone know if the new turbo actuator needs calibrating or "learning" to the van's computer after fitting, or does it just sort itself out? Tbh I'd have thought a two month old one would be fine, but then the P0045 code does seem to point that way, doesnt it.
MagsH72
Postby metalworker0 » Wed Oct 21, 2026 11:41 pm
i dont know , ive said things to check, and he does not say he has checked them .
the actuator test .. and if the actuator rod is bound up or the vanes themselves or the gearbox
i say this ... to rule them out .. before going on to a wiring fault or a pcm fault.
the checks are quick, and take minutes.
only this is going on over days
im trying to cross things off the list first
Users browsing this forum: Baidu [Spider], Google Adsense [Bot]
