p2thed wrote:The affected vehicle range
Chug wrote:If you read back through this thread all the info you should need has been posted and is copied from Ford, they know its not fit for purpose but try and wriggle out of it.
See also this thread........ viewtopic.php?f=65&t=222053
Direct link to the FSA 20B44 post
viewtopic.php?f=64&t=204983&start=105#p1750970
scroll down that page to find this bit.....
Consequential Damage
If the timing belt delamination is not identified early, it could result in timing belt failure. The timing belt can fail in two ways, teeth can start to shear off the belt allowing the timing to slip or the belt can snap, both will cause poor running and lead to valve and piston contact. At this point the engine will need to be replaced.
The FSA will cover the costs of replacing the engine if it has failed due to the failure of the timing belt as described above or oil starvation due to excessive debris cause by delamination of the timing belt.
If you have identified an engine that has failed and the cause is confirmed as timing belt failure, you can bill the engine replacement to the FSA as a bill of material claim. Please submit a bill of material claim including all parts, labour and replacement vehicle hire required to complete the repair. The FSA no. 20B44 must be entered into the program code field. The labour time that can be claimed will vary depending on vehicle variant and if the repair is completed in combination with a routine service.
cornishpasty wrote:We had belt break on 3.5 year old van and Ford have fitted engine under warranty even though out of it.
Van less than 100000 miles.
They are surely admitting a problem.
metalworker0 wrote:in the second picture you can see what looks like a strand of belt material ...lower right side, when the picture is opened up , if that is a long strand ..then yes, it's time to change.
all the best mark
metalworker0 wrote:The strands seem to end up at the other end of the head in the vacuum pump..perhaps take that off and have a look,, the vacuum pump failures have been reported before the belt failures due to getting gummed up with these strands /fibres.
as the question new belts and old ones, we don't have that info, with all that is going on ....not many are coming here and telling us .
you can count on your hands the amount reported here- so cant make up stats with that.
