So the Mk8 features this Easy Fuel thing.
Basically the cap is closed and only opens when you put in the ... end of the hose. And the cap closes instantly after removing the hose. You can use a plastic funnel that you get with a van for this. But the funnel is too small for the hose at the station. So it can be used for emergency refueling.
This thing s supposed to be all smart and good.
But every time I use it, some fuel ends up on my car.
Because you know, you cannot just fill UP like FULL UP your van with this thing anymore. And worse, even if I wait a minute after the refuel finished - there is still some fuel left in the hose.
And when you pull the hose out, the cap closes instantly, pushing out fuel.
My question: How is this thing treating you guys?
Does it work for you?
(I tried Shell stations as well, but this happens with every station.)
