What was ford thinking when it did the interior lighting?!
Postby Damien89 » Fri Aug 07, 2015 8:25 pm
So i removed one of the interior lights to see what bulbs are in them, and found out that they have puny bulbs in a huge bulb holder, they should put 2 10/20 watt bulbs! Will see whats available to upgrrade.
Damien89
Re: What was ford thinking when it did the interior lighting
Postby joiner12007 » Fri Aug 07, 2015 8:50 pm
I opted for the optional LEDs I have to say they are fantastic really impressed with them and well worth the £80 extra that they cost.
joiner12007
Postby Altransit » Fri Aug 07, 2015 8:52 pm
Hard to believe that in this day and age, that they're not fitting LED's as standard in the cab and load space :?
Very easy to upgrade yourself though :D
Postby loot » Sun Nov 15, 2015 12:12 pm
Looks like all the leds in the speedo have built up a surplus of bulbs so they've put them into the interior lights :lol:
Ids map here
loot
Postby Damien89 » Sun Nov 15, 2015 5:05 pm
Altransit wrote:Hard to believe that in this day and age, that they're not fitting LED's as standard in the cab and load space :?
What can i do to upgrade them to led's?
Damien89
Postby jonhunt85 » Sun Nov 15, 2015 10:16 pm
the pic of the bulb holder where was that in the transit as it don't match any off the lights in my Mk8 Trend
Jon Boy Services
2015 Ford Transit Trend 125.350 L3/H3
http://www.jonboyservices.co.uk
http://www.facebook.com/jonboyservices
jonhunt85
Postby blue estate » Sun Nov 15, 2015 10:18 pm
Get the festoon type out of a mk2 focus as my estate has same lights in it
blue estate
Postby Altransit » Sun Nov 15, 2015 10:26 pm
I fitted these LED Boards in mine, and the same in the load space lights 8)
Postby Damien89 » Sun Nov 15, 2015 10:35 pm
jonhunt85 wrote:the pic of the bulb holder where was that in the transit as it don't match any off the lights in my Mk8 Trend
That was one of the rear lights in my minibus.
Damien89
Postby Damien89 » Sun Nov 15, 2015 10:36 pm
Those light holders are different then mine, are they brighter?
Damien89
Postby Altransit » Sun Nov 15, 2015 10:40 pm
Damien89 wrote: Those light holders are different then mine, are they brighter?
Yes, I noticed that after I posted :oops: Those are Mk6/7 lights, and the LED's make them much brighter, so that I can read my paperwork without an additional torch.
You'll have to do some mods with your holders, or maybe find one from another model that fits in the space
Postby Damien89 » Sun Nov 15, 2015 10:42 pm
I found these, do you think they would fit?
Damien89
Postby Damien89 » Sun Nov 15, 2015 10:44 pm
These are others i found which show the backside.
Damien89
Postby Altransit » Sun Nov 15, 2015 10:47 pm
Hard to say without seeing your light up close, they do look the right shape, but can you get into the section where the business part of the bulb sits :?:
If it's sealed, you may need to source a different unit :|
Postby loot » Mon Nov 16, 2015 3:43 pm
I reckon there just the treat :-) the clear part of your lens needs to come off then push it into the bulb holder, make sure it is the right way to fit into and put the lens back on 8)
Million dollar question is..... Are your clear lens clipped on or welded on :?:
Ids map here
loot
