Live data shows throttle position goes only to 78%?! Martynx
Postby Damien89 » Sun Aug 09, 2015 4:05 pm
Hi, everyone,
Connected my laptop to see what the sensors are saying and noticed that the throttle position sensor is only reading 78% when the pedal is pressed all the way, is this normal? Has anyone that maybe read some live data encountered this? Martynx have you encountered this symptom on a mk8?
Damien89
Re: Live data shows throttle position goes only to 78%?! Mar
Postby Damien89 » Sun Aug 09, 2015 4:11 pm
I'm including a video clip showing the sensor percentage when i press the pedal all the way to the floor.
Damien89
Postby karl » Sun Aug 09, 2015 4:54 pm
the mrk 8 is still new and not many know much about them including me :(
karl
Tranny Lover!!!
Postby Luke » Sun Aug 09, 2015 5:02 pm
where are you from damien89 :?:
if nobody knows there might be a member local to you to try it on his/her van to see if the result is the same :idea:
Postby Damien89 » Sun Aug 09, 2015 5:14 pm
Malta, europe. Never thought about trying another van to compare, our cooperative has 4 new mk8's, i'll see if they let me check one of them.
Damien89
Postby loot » Thu Aug 27, 2015 7:53 am
I'm fairly sure my mk7 doesn't go to 100% either
Ids map here
loot
Postby mjsroofing » Sun Oct 04, 2015 12:16 pm
Isn't there an option to recalibrate
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby loot » Sun Oct 04, 2015 12:38 pm
I don't know of any but then you'd expect the pcm to know what to do since it has various other information available to allow it to trim the throttle anyway, i would suspect that 0% and 100% need to be a resistance of some sort because it stops the pcm seeing an open circuit. I'm sure my throttle never goes fully across the green bars when i test it. :wink:
Ids map here
loot
Postby V184 » Sun Oct 04, 2015 4:55 pm
karl mcghee wrote:the mrk 8 is still new and not many know much about them including me :(
Probably best kept that way Karl :wink: :lol: :lol: :lol:
V184
Postby bambi mk 1 » Sun Oct 04, 2015 5:13 pm
Now now Ned Flangers
bambi mk 1
Postby V184 » Sun Oct 04, 2015 5:58 pm
Probably best kept that way Karl :wink: :lol: :lol: :lol:[/quote]
Now now Ned Flangers[/quote] :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
V184
Postby mjsroofing » Mon Oct 05, 2015 9:46 pm
loot wrote:I don't know of any but then you'd expect the pcm to know what to do since it has various other information available to allow it to trim the throttle anyway, i would suspect that 0% and 100% need to be a resistance of some sort because it stops the pcm seeing an open circuit. I'm sure my throttle never goes fully across the green bars when i test it. :wink:
Sorry I was thinking of op-com which has a re calibration option.
mjsroofing
Postby ake » Tue Oct 13, 2015 6:46 am
This has been covered before, on MK 6 or 7, but the answer was to carefully file away the pedal back stop, to allow full travel ;)
Postby mjsroofing » Tue Oct 13, 2015 12:07 pm
ake wrote:This has been covered before, on MK 6 or 7, but the answer was to carefully file away the pedal back stop, to allow full travel ;)
Does this give you an extra 20 ponies too.
mjsroofing
Postby Damien89 » Tue Oct 13, 2015 1:11 pm
Or maybe it uses all the 155hp instead of the vans feeling gutless under 1500rpm.
Damien89
